1998 Stewart and Stevenson M1079 For Sale
1998 Stewart & Stevenson M1079 4x4 EMP-Proof Military Truck Camper w/ Winch LMTV FMTV
Low Mileage, Street Legal, Unimog, Excellent Condition! - Perfect On or Off road!
-Cat 3116 with 225 horsepower the engine is the non-electronic, highly dependable
-Heavy Duty Allison 7-speed automatic (push button)
-5 BRAND NEW tires (Includes new spare)
-4 BRAND NEW batteries
-Adjustable AIR RIDE CAB
-US Government spent over $165,000 New
- Gray Primer over original cammo (you can paint whatever color you want or leave it grey primer)
-Street-legal, WA plates, clean title in hand
- Blast-Doors
-EMP-Proof (Electromagnetic pulse ) Worth its weight in gold for just that option! The military spec this truck out that way.
-Includes Self-Recovery Winch Kit - RARE- capable of fore and aft vehicle recovery operations. The winch has 308 feet of line capacity and 10,000 pounds bare drum line pull at 110% overload. (not installed)
-Transportable stairs that easily attach for easy entry and exit
-Turn Key 100% Ready To Go Work Or Play
Interior:
The interior is what you would expect from the military, the drive cabin has 2 comfortable seats and plenty of cargo room and mounts for a table or a 3rd seat. There is a 3rd seat-belt in place already. Everything works as it should. The rear insulated camper is bare and ready for build out. It has a pre-set 120/208V/3PH/100A/60Hz power distribution panel that controls permanently mounted 120V electrical outlets placed along walls- all lighting and power in the back is already wired and works. Includes 24VDC emergency and blackout light system The windows open easily and the doors allow plenty of access for new cabinetry and ventilation.
Exterior:
The exterior is recently painted grey and can easily be changed to any other color as it is light. All 5 Tires are BRAND NEW. All the lights operate as they should. Comes with new wipers as well.
Drivetrain:
This beast is powered by a 3116 Cat motor producing 225hp and hobs of torque. The drive-line is tight. Runs and drives excellent. CTIS is perfect and functions as it should. Swapped diffs to synthetic fluid to improve improve range at high speeds.
Key Facts:
Listed is a rugged off-road EMP PROOF ex-military m1079 camper truck that will go anywhere you want it to. 6,905 original miles! Yes! 6,905 original miles. This truck is like new. Comes equipped with a snorkel intake and great ground clearance. the 3116 cat turbo intercooled engine runs like a clock! The Allison 7 speed automatic shifts great! CTIS is perfect.
You will not believe how nice it rides!
Will run 58 mph and stop on a dime! the truck runs and drives perfect.
The cab and spare tire are air over hydraulic operated. No lifting the spare up or down. Has 2 trailer plugs, one 24v and the other 12v. All of the lights work perfectly. New tires are 395/85/20 with 100% tread! No, smells, noises, nothing. runs and drives perfect.
This truck is perfect for an off-road RV camper conversion, work truck, swat vehicle, mobile command station, parades, Zombie-apocalypse vehicle or just a toy to add to your collection.
https://fas.org/man/dod-101/sys/land/m1079.htm has more info about the M1079 as well as many videos on YouTube. Note: there are additional parts in the winch kit not pictured, but everything is there.
call or text 805 451 2844
Located 2hrs north of Los Angeles CA
$29,000 OBO
dhuss
