New Defender News
soflorovers
As @JackW stated, I would love to see more operational reviews of the 4-Cyl. If the 4-Cyl is as capable under 80% of the loaded specs for overloading it by definition makes the 110 with 4-cyl the likely choice for those not wanting to pay a $12k upgrade or wait around for the possibility of the diesel in the NAS market.
Would be nice to see what exact vehicles if any difference were on these rallies and what powerplant differences if any from LR to show that they are either comparable or not for the same adventure as the one sitting next to it.
I hate to burst your bubble (and my own), but diesel is a dirty word at JLR NA. I've spoken to a fairly reliable source who has stated JLR has no plans to introduce the diesel in the USA, and instead are going to focus their efforts on PHEV/electrification. IMO, the writing was on the wall as soon as we saw them drop the diesel option for the 2020 Velar; I imagine we'll be losing it in the rest of the lineup for 2021. I'm really hoping JLR pulls their heads out of their (insert expletive here) and gives the people what they want, but I'm not getting my hopes up.
soflorovers
My opinion will be all over Craig’s list under mechanics special tag in a couple of years.
If you give free vehicle to any organization they will take it,
Now ask them to buy and see what they buy.
Article doesn’t mean anything about vehicles quality.
The irony of this statement is that it's coming from the man who's profile photo is an RRC - Probably one of the least reliable cars ever made. This new Defender can't possibly be worse than what you're experiencing.
I hope we are wrong here........lol But, like my statement before; this is where I am debating a 4-Cyl purchase option D110 as a backup plan.
soflorovers
For perspective, the new 4cyl defender has as much HP as the V8 LR3, and I believe it weighs less than the D3. 300 hp should be "sufficient". That said, I'd aim higher if you plan on stuffing a large tire like some of us idiots.
mpinco
I would think the 4cyl 2.0L would struggle at altitude and/or towing. Would like to see a torque curve but its already down 25% from the LR4 V8 and altitude will reduce that another 20%.
soflorovers
Maybe? FWIW, forced induction tends to fare better than N/A counterparts at altitude.
nickw
It's still 2 liter ..............
That's what they said about the 2.7 EB and 3.5 EB in the F150 and they are work every bit as good as the V8's. If you look at the 2.3 EB in the Ranger, its has more low end power than it's contemporaries and is on par (if not better ) than NA V8's a few years back and exceeds pretty much all NA V6's. This new LR engine looks to be sim power output to the 2.3 EB, I have no concerns that it will lack power.
I do think people have come to EXPECT massive power out of SUV's over the years, it won't be a race car, but 300 hp is more than enough for a rig of this size.
It has more torque lower down than the old 300TDI's and significantly more power....
mpinco
My point was for towing and at altitude. Altitude as in 8,000 to 10,000 ft, on average. It's all about torque, not hp.
Believe its a twin-turbo 4-cyl if I remember correctly and turbo normalizing negates altitude considerations; hence why it has a turbo.
@soflorovers Agreed; seeing the torque curve will answer the remainder of the questions!
@mpinco that part about "it's still a 2 liter" is not valid if the map/curve is right for the vehicle and configuration in placed in.
LR Spec 2.0 Liter 4cyl: 296hp @295lb/ft
Cummins R2.8 (arguably the best crate motor anyone can buy): 161hp @ 310lb/ft
Look like pretty good numbers to me! But ask me about turbos and high altitude performance and normalizing in aviation cuz I'm not an LR engineer so they probably did better math on their vehicle than I did; one can only assume! Is density altitude on the ground at 9600ft the same as density altitude for the aircraft flying by at the same altitude; guess that depends on if we are turbo-charging or turbo-normalizing; modern ECU's can use variable turbos and manifold pressure to do both on the desires of demand.
In simple terms; turbo-charging alone is for on demand power required and turbo-normalizing maintains manifold pressure very similar to supercharging (I said similar in concept) in all environments so the vehicle does not perform any different through its entire operational range due to demand needs, altitude, etc. Means your power/torque curve does not change regardless of the environment under computer control. Generally, turbo-normalizing is not as ideal on engine life as compression/manifold pressure is always high where as turbo-charging is on demand only.
Disclaimer: these are simple terms in simple explanation.
Tho
