Front Locker is it needed?
Oncewaspfd
I just purchased a 2018 4runner off road premium. I'm planning my first overlanding build. I don't do any rock crawling. I want to start with suspension lift, larger tires and new wheels. Regearing is also in the works. Do I spend the money for front lockers and a compressor or just regear the front end?
billiebob
yes !! do the lockers both ends but there are e-locker options too if you want to eliminate the air compressor expense and plumbing. If you are opening up the axles add lockers too.
I value mine more for the ability to tread lightly, go slower, eliminate wheel spin and trail, watershed degradation, and ease the wear and tear on the vehicle. Lockers let you crawl up or down slopes without losing traction.
Tex68w
Beach Bum
I would skip the front locker for what you describe, very few need them. If you want to spend the money while you have the front diff open for a regear then that would be the time, up to you, but I'd pass.
Dopesick
Does a bear..........
Personal opinion... Locker no. Limited Slip, sure. You'll have the diff out to re-gear, do it all at once.
jadmt
ignore button user
On a 4runner you need a pretty good size lift to run big enough tires to need a re-gear Unless you want to do a lot of cutting.
greg.potter
You only need a front locker ...... when you need it. For me having a front locker is a "piece of mind" accessory. With my Jeep I It has been engaged a few times to gett unstuck, steep or low traction situations and pulling out stuck vehicles - my Jeep gets used to get me from A to B, not as a rock crawler. Is it necessary - probably not. If I was purchasing a new vehicle or was planning on re-gearing would I put a locker in again - for sure. It's a "piece of mind thing".
jadmt
ignore button user
Buddy bought a new 2020 4Runner and put a Falcon lift on it. It looks really good but in reality not much room for bigger tires than stock.
Scott Brady
Founder
If you are not rock crawling, save the money and use it for fuel to go someplace cool. The 4Runner has a very effective traction control system, and when combined with the factory rear locker, it is an excellent performer off-road.
Use caution taking any advice on the suitability of a limited slip for the front axle. We do not recommend any traction device for the front axle that is not driver selectable due to the risk of understeer, poor line holding on side slopes, etc.
jadmt
ignore button user
agree 100% I have been running lockers for many years and do a lot of winter snow wheeling and no way in heck would I run a non selectable up front. I would not want it in the rocks, or slick roads either. You can do the rubicon trail without engaging front lockers.
Henrybrowne
