2015 Ford Transit Camper Van For Sale
StanH
Hello, up for sale is a 2015 Ford Transit Van, here is a link to the build that was done almost 5 years ago
http://www.expeditionportal.com/forum/threads/148735-Ford-Transit-build-out
Not much has changed with the van, it is still 2wd has not been wrecked. It does have a couple light scratches but no dings or dents. The Van is located in Fresno, CA. It has 36,281 miles on it at this time, and was just Smogged last year with no problem. We did have a few of the batteries die so instead of purchasing new ones, we just removed some to equal out the banks.
$42,500
Here are some of the particulars
3.7 V-6 Medium roof, 148” wheel base, long
3.73 gear ratio
9000LB GVWR package
Passenger side seat swivel
custom headliner and upholstery
Upper cabinets and under sink storage
12v/110v Nor-cold DEO788B 3.1 Cubic foot fridge
sink with counter top
Folding sofa, into bed and fold flat against the wall
KingTec K20D2 DC 12v air con
Sound system:
Pioneer AVH-4100NEX
Amps
Speakers
8” sub
Electrical:
All electrical wiring and components are marine grade. All 12v wiring is 12g, All a/c wiring is 12/3 flexible.
1000 AMPS CALB LiFe-Po4 batteries with integrated BMS controller and 400Amp isolater
T-class fuses where needed
2 position battery switch
Sterling battery to battery charger
(2) Kyocera 140GX-LFBS panels in parallel to Bioenno SC-1220JU 20 AMP solar MPPT controller
30 Amp Smart plug and cord for shore power
30 Amp BlueSea a/c main breaker
30 Amp BlueSea a/c panel with (6) 15 Amp breakers
controls
water heater
4 outlets
frig on shore power
radiant floor heating
1 spare
4000 watt inverter/battery charger (draws 5 amps with no load)
Switched 12v panel for
lights
water pump
12v outlet
usb outlet
max fan
Plumbing:
Copper and copper PEX connectors
25 gallon water tank
12v Shurflo on demand water pump
Isotemp 10 gallon a/c water heater (can be hooked up to engine coolant system to provide constant hot water)
Sink with faucet
Shower with mixer off of the back of the vehicle
sprayer with hose off of the back of the vehicle
Cabinets, mechanical well and bed were framed from 80/20 extrusions
All plywood is 3/4” oak
Misc:
Radiant floor heating
Air conditioner can run for days on the batteries with no shore power
Completely Insulated with 3M insulate and sound deadening throughout
Floor was insulated and has 3/4” oak plywood
Aluminess rear bumper, swing out tire carrier and swing out galley box
Aluminess roof rack500 LB slides for toilet already installed (toilet not included)
Thank you, Stan (559) 790-6677
Vanaddict
What do you mean by the AC can run for days? I've always heard it's nearly impossible to run an air conditioner without a generator
Jdubucsd
Addicted to Espresso
How well does the AC unit run off the battery bank? Just 6-7-8hours at 50% duty cycle or?
Msand
Importer
Copied from the original for sale thread- people then proceeded to bash StanH because of the massive price increase when he posted the vehicle for sale again for a much higher price.
""Price drop!! Leaving the country on 5/28 Van must go!
New price of $25K OBO the house LiFe-Po4 batteries are not included. You can buy a similar set up depending on Amp hours between $4K and $7K. I'm selling the van for about $2k above blue book .....like I said I'm leaving for Thailand on 5/28 not sure when I will be back. Van is currently near Phoenix, AZ.
Thanks for looking.
Jason
831-252-1088""
stone23
