FS/FT 1983 Dodge D50/Mighty Max 4WD
Prescott
Sadly, I am selling the whole lot. I have enjoyed countless trips in this truck and it will be missed very much but it is not my daily driver and having an extra vehicle just doesn't make sense anymore.
So the truck itself. (pictures are taking a minute to load so I will have pictures of the truck up in about an hour)
Engine/Tranny: It is a 1983 D50 4WD. Currently I am waiting on the exhaust header from Australia but that should be here within the next weekish. The cylinder head was removed about 500 miles ago and sent to the machine shop to have it gone through. They cleaned it up and said everything was WNL. I replaced the head gasket, water pump and thermostat before getting it all back together. It has an electric fuel pump and a Weber Carb. The transmission is in good shape and the PO stated he replaced the clutch before I bought it. It shifts with no issues and the 4WD works without any complications.
Suspension: Basically the entire front end has been gone through. There is a the receipt in the pictures from rockauto of all the things I ordered and replaced. Additionally it has the Sway-away torsion bars and lift blocks from Adventure Driven Design. The previous owner put on a later model leaf spring set that helped with the lift as well. Tire size is 265/70/16 and those are in good condition.
Interior: The interior is bitter sweet. The bench seat is in really good condition. The dash is cracked like all the others but it does have a dash mat that helps. It doesnt have any carpet but I added Noico sound deadening just about everywhere which really helped with and road noise. It has aftermarket gauges for the Coolant temp, oil temp, RPM, and oil pressure.
Exterior: It needs paint. All of the panels are in good shape but the paint needs to be redone. I have two fenders that are in good shape that I will sell with it.
Price: $3500
attachment.php
Prescott
I will also entertain trades/partial trades for camping equipment. Tents, RTT, fridges, solar system set ups and the like.
zhukoveli
