I usually use a golf cart solenoid as a battery disconnect much like Rayras system. never had a problem with them. however i have seen people on the trail with fried solenoids due to long hard winching. maybe they used a smaller solenoid.
the only reason you would have an issue without running an isolator is if you use two different age/types of batteries. the weaker battery will always try and draw down the stronger battery. look under the hood of any older diesel they have two batteries and no isolators, but they always replace those batteries in pairs. i figured between the smart alternators being sensitive and the winch needing all the juice i can feed it that i would be better off without the isolator. i also have the aux battery pack for my accessories so no worry about my fridge drawing down the starting batteries.
i bought a hypertech 2.0 and turned up the power a little bit, firmed up the shifts and turned off the AFM. i really like the programmer. you can customize each shift point for every gear and you can set the speed you want the AFM to kick in at or turn it off all together. haven't had it in long enough to say if i gained or lost MPG, but it certainly sounds better and the compression braking is consistent now.
i also installed a pioneer touch screen receiver so i now have satellite radio and a back up camera.
here are some pics of the skid plate that i replaced the plastic one with. found it on ebay. bolted up easy breezy and certainly looks nicer than the busted up plastic one that it had on there.
