AZ 2nd gen Dodge Ram with Alucab awning
I do a lot of mild off roading exploring the southwest part of the US. Being stuck without shade in this area of the world is not good for the skin in the long term. As such I’ve used pop up shade tents for years. That gets old after awhile. A few years ago the AluCab products made it to the states. They‘ve been in the outback of Australia for quite awhile. Well tested equipment that just happens to be well built and very user friendly.
Decided to install one on my truck. While the awning is a well proven product, if you don’t use one of their roof racks and mounting brackets, you’ll need to be a bit crafty. My goal from the beginning it to be able to keep the vehicle from gaining excessive height front the install. Needs to be able to park in a standard size garage. And I wasn’t looking to have storage on the roof. I ended up installing aircraft style seat rails to my low profile fiberglass topper. No idea of the make of the topper. Bought second hand a long time ago:).
I used a 1x2 piece of oak wood on the inside of the camper shell. Mounted the rails to the topper using countersunk screws that bolted to the inside of the camper shell. (The oak wood helps to distribute the load and forces of the canopy). Once the seat tracks were installed I used some tubing and some flat plate steel to make the four corner mounts. I had intended to have these welded up. I suck at welding and didn’t have the equipment anyway. Just bolted them together. I did use two cross bars from Alu cab to assist in mounting the awning.
The tricky bits.
1. Ensuring the canopy won’t interfere with the suicide doors and still fits in the garage.
2. Making a strong support mount for the main support for the canopy.
For the first item. Just took time measuring to see how much clearance was needed for the awning. Lot’s of time measuring and scratching the noggin. Throw in some luck and it all worked out.
For the aft mount. This needs to be as stout as possible. The awning is designed to be able to be used with no support struts or tie downs. (for most conditions). I ended up using a chunk of 4x6 inch steel tubing. Used a cutoff wheel and an angle grinder and split it in half. I used a couple of the mounts included in kit for the awning to assist mounting to the tubing for the rear mount. The forward mount doesn’t carry much torsion loads. Just the weight of the canopy when it is stowed. Used the mount that came in the kit for this as well.
Additionally I have added strip LED lighting to the three support bars. And two strips of led lighting on the rear window of the camper shell. Put this on an dimmer. Goes from barely lit to the equivalent of daytime lighting under the canopy. To power all of this and other electrical loads for primitive camping ie. refrigerator, inverter, diesel heater for my tent, charging batteries etc... I have installed a solar system. Have a victron charge controller, 100AH batt fed by 300 watts of solar panels. I had originally installed a 165 watt panel that was one of the semi flexible panels. I had that bonded to the camper shell. Failed after a year of use due to the excessive heat we have here. Removed it about a month ago and put in the new panels. They weigh quite a bit more than the flexible panel.... But they‘ll last a long time.
I’ve had this on the truck now for well over a year. One of the best and most useful mods I’ve done so far. Enough of my rambling. Pics should help.
A few more pics. The dinner pic was taken way after dark. No flash. Just the lighting from the LED’S. Two other pics show my home brew portable diesel heater. Use this for camping when it’s a bit nippy here. Makes a world of difference camping in a tent. (Shiftpod 2)
Think of it more as a portable shelter. Last year we took a cross country trip. Really wanted a trailer. Couldn’t justify the cost and storage etc...... Settled on the shiftpod 2 tent. Can’t say enough good things about it. In the last year we’ve spent over 30 nights in it. Some were just overnight and some were multi day affairs. The tent is extremely quick to setup. Like 2 mins or less and it’s out of the bag and up. Takes us another 7-8 minutes to put in a 8x10 floor mat and to inflate the beds. Teardown is the reverse order. Does help to have two people to squeeze the air out when your packing it down. I’ve done it numerous time by myself though. I use a 12 volt shop light for illumination. The inside walls of the tent are white. Light works real well. The real key to all of this is the heater. When it’s cold and damp, it’s like stepping inside your home. Nice and dry air. When you wake up in the am, you’ll be treated to dry sheets, clothes etc. Does well in the high heat as well. Just came back from a trip. Temp on Saturday was 107. We were able to sleep in and the heat didn’t warm up the tent In the am. (Tent was designed for the desert enviroment)
Plenty of room to stand up inside, setup up a chair and table inside if needed. We’ve done that when it’s been raining. Can’t say enough good things about it. In my eye it’s as good as it gets for tent camping (tent glamping?)
Normally don’t use the blast shield. Only if torrential rain is on the forecast. And we don’t normally stake the tent down unless it’s fairly windy. Around
15-20mph the wind will push in the sides. But once you stake the tent down on the sides. No wind outside of a hurricane will this tent collapse.
You do want to make sure it’s dry before you put it away. (like any other tent). The outside of my tent lost a bit of it’s shine due to this in a few places. I didn’t get it out from packing it up dripping wet on one trip last year.
https://shiftpod.com/shiftpod/shelter/shiftpod-v20
How do you like your Shiftpod?
vintageracer
To Infinity and Beyond!
I also have a Shiftpod.
Your experience with your Shiftpod mirrors mine.
Expensive?
Yes however like anything else buy once, cry once and enjoy!
Scoutman
Looks cozy in that tent. How is airflow with those little windows?
Any pictures of how you mounted the led's to your awning rails? My AluCab awning is probably my favorite and most used piece of equipment I have.
Airflow = decent. Both doors have screens as well.
I'll get some pics of the install of the LED's. Here is the links to the parts though.
tape for mounting strips
Mounting strips
LED's
Dimmer for LED's
Here is some pics of the LED lights installed. For the arm that has a support leg. You’ll need to drop the support bracket down by height of the LED’s. New bracket will be required to hold the leg up as well. My bracket is a bit dodgy, but does what it’s supposed to do. Getting the wiring from the vehicle to the canopy can be a bit tricky. Drilled a hole through the support rail for the canopy, into the void in the alucab cross rail, another hole on top down through The cross rail, through the support bracket, through the seat track and supporting wood inside the topper and voila the wiring is hidden from view and works! Lights are on all three arms of the awning and two are on the glass swing up door of the camper shell. Full power they pull 5 amps. I rarely will crank it up that high. Normally half or less will suffice. Lowest is .5 amps on full dim.
oskarf150
