Customized Ford F550 7.3 Flatbed Truck Camper - GREAT BOONDOCKING RIG
FOR SALE
2TqVpvBaYkqPExvUees7dpplfKtKMFCmR-as7FTGmtOZb-bLgr-5YdW5BXxMkkVk5m7_HwsQ0W8ZcOGxHXP4SH764YfjDZDBSY07ch8AcbxwWwGckvDCdNrjrvZHOssiZzQiWvY-
OwGqkzKQyT9LcPbOlpKSMlg-u44qkn0zOhTxMSYRueOGYtXQODIxD99bIY2MsToAAnJYpJVUDVbqLdL-4kUNCzNClxjiCHWUtAv_wqeu_qChdozbyvwjkrq1AEdUOmD9qVM5rsPr
2001 FORD F-550 WITH CUSTOM FLATBED AND CAMPER
BRAND NEW FORD REMAN ENGINE
BUILT FOR BOONDOCKING AND CAMPING OFF-GRID
Please read below as this truck and camper have had SIGNIFICANT modifications.
It has been an awesome full-time boondocking rig for us but we’re ready to move into an even smaller rig.
We were recently featured on Tiny Home Tours and that video gives a great overview of the rig (and thus why I’m not posting many pictures, you get a much better view in the video) but there are some systems not mentioned so please read the entire list below as well. https://youtu.be/-fzAO2N_Dkk
Mentioned in video but not included: Baja Designs lights on bumper and ARB air compressor.
Titled as an RV. Clean SD title. Currently located in Springfield, Missouri.
TRUCK
2001 Ford F550, 4x4, manual transmission
Ford 7.3 Reman engine with less than 5k miles (and only 195k miles on the chassis). Miles will go up some as we are still driving it.
New KC Turbo and pedestal
New glow plugs with engine
New water pump with engine
Air ride system
New DP Tuner installed with 60hp Codes for Towing and Hi-Idle RPM - 1400 - for Warmup, Boost A/C output, Running a Winch, Jump Starting (also stock and kill switch positions)
Upgraded RiffRaff Diesel air filter
MaxTow Pilar gauges for EGT, boost, fuel pressure, and water coolant temp
Custom iron bull bumper (winch ready)
Upgraded radio with Bluetooth and backup camera
Custom kill switch
Cab has Noico soundproofing installed
TRUCK BED
Custom built storage, steel framed with PVC panels and heavy duty stainless steel hinges and aluminum trim
Truck bed modified to fit 41” tires (like MPT 81’s) if desired (room for 41” spare tire in the storage boxes as well)
Hidden pass thru from camper to truck
See video of storage build here: https://youtu.be/17HEZCxZU9I
Camper
Major systems all gutted and redone
Propane completely removed
Espar diesel hydronic heater for air and hot water with 4 new vents in cabin plus 1 into basement to keep tanks warm in extreme cold. All vents can be controlled separately. Hot water is INSTANT.
Separate 5 gallon diesel tank for Espar system with gauge in cabin
High altitude kit installed on Espar
Espar Easy Start controller + thermostat
900 Watts of solar (Five 180 watt Grape Solar panels wired in parallel)
780 amp hr battery bank (Six 120 amp hr Victron AGM batteries)
Midnite solar classic 150 charge controller
Xantrex 2000 watt inverter/charger (with remote display) - controls convection microwave, rooftop a/c, kitchen outlets
Victron 300 watt inverter - powers all other electrical outlets and TV, saving power by not using the larger inverter
Airhead composting toilet with urine plumbed to black tank
3 stage water filtration system
40 gallon fresh water
32 gallon grey water
28 gallon black water (used for urine from composting toilet)
Mofi 4500 cellular embedded router
Poynting 5-in-1 MIMO (LTE + WIFI + GPS) antenna on air actuated lifting mount powered by ViAir compressor
Reolink security camera with night vision
Vitrofrigo 7 cu **** MARINE fridge/freezer (compressor fridge with no ammonia)
Updated kitchen with 2 huge pull-out pantry’s
Convection microwave
Portable Induction cooktop
Rooftop A/C which can be started off inverter
Custom 7” queen foam mattress
Huge clothes storage in bed area
Upgraded MaxxFan Deluxe with remote
TV with built in DVD player
Upgraded door lock with keyless entry option
All LED lighting
100% aluminum and composite construction!
Only wood is the table and 2 pull-out pantry slides
Built by Livin Lite BEFORE being sold to Thor
Truck is currently mounted with removable Torklift fast guns. Jacks have been removed but are stored under the chassis making the camper removable at this point.
ASKING PRICE: $60,000
RAM5500 CAMPERTHING
OG Portal Member #183
I've followed you guys on IG and YouTube for awhile. I find your videos and personality differences awesomely hilarious (especially the toilet comparison video, hahaha)!
Great Rig done right.
Question, since I'm sure someone else will ask it...
Can the camper be hard mounted through the floor so the exterior storage boxes can be accessed easier?
Can the camper before hard mounted through the floor so the exterior storage boxes can be accessed easier?
Hahaha thanks!
Yes, I believe it could be done with some forethought and planning. We never did it because we have a total of 6 boxes that are accessible without removing the tie downs. We just kept our most frequently used items in those boxes.
bgflyguy
Once I figured out how to configure the MOFI, it worked perfectly. I use google fi currently but I've used AT&T and Verizon with it also.
Sorry to side track the thread. It looks like a great build, but I'm currious about this as well. Does this use the multi-sim+wifi Google FI functionality or is it T-Mobile only?
sunnyaz
