Alloy
I got the 7075 links made and installed--Summit Machine in UT makes them for less than I can by the raw material. They are solid (not hollow), as strong as mild steel, and bend like mad while returning to the original shape.
I was able to go with a smaller diameter on the panhard bar, which allows for more clearance with the diff as well as the mounting point on the right. I changed the pitman arm as well to less drop. The drag link and panhard bar are very close to parallel and are equal in length. The tie rod is 1.5" in diameter.
A solid rod of 7075 aluminum is much lighter than 1/4 wall DOM steel, so the weight of the rear tank bash plate is offset by the aluminum links.
If you haven't already.....a little silicone grease will prevent the dissimilar metals from corroding like crazy.
