So I thought I'd start a discussion to see if people might want to admit (or at least be open to the idea) that some of us carry more tools than might be necessary.
I was very inspired by Jonathan Hanson's writings on his tool kit back when I got started in Overlanding, and I've definitely obeyed the rule of "If I use a tool from the shop to work on the rig, the tool gets moved (or duplicated) into the rig". The problem, now, of course, is that I probably have somewhere north of 50lbs of tools in the van.
This year I've been putting the van on a diet (in a lot of places), and it's time to address the tool kit. I'm hoping to use a more focused set of criteria for evaluating which tools to keep. In its current configuration and use, my rig is basically a short-term camper, in North America. I know we all fancy ourselves world travelers, and if I were planning to do Morocco to Capetown or something, then obviously I'd need a more comprehensive tools (and spares) package, but the reality is that right now this rig gets used for 3-day to 2-week trips, with a mix of highway and soft-road travel. No rock crawling, no solo treks across the Rub' al Khali. More than that, I need to realize I'm basically driving a Minivan with pretensions to greatness - over-preparing actually causes it's own set of problems because I don't have the payload budget of the "big boys".
Of the myriad tools I've carried in this rig for the last 10 years (holy crap I've had this van 10 years!), the tools I've actually used in the field comes down to a shockingly short list. (Multi-bit screwdriver, a few combo wrenches, side cutters, pliers, snap knife...) Obviously I'm not going to remove every tool that's never been used - a lot of the stuff that's there is there for the reasonable "what if" scenarios - things I might reasonably be expected to face (and tackle) on my own. But let's face it, in the places I'm going to be traveling in the foreseeable future, the tool to fix a torn CV boot is duct-tape and zip-ties, followed by the swift application of a cell-phone and a credit card.
I promise I will re-spec and re-pack the tool kit if the mission changes, but until then, I'm keen to knock the tool kit down by about 10lbs, at least. First pass was to eliminate the majority of the SAE tools. The van is metric, aside from a few SAE fasteners added when I built the new bench/bed conversion, etc.
Next pass is to re-evaluate the "nice to have" vs. "need to have" and the redundancies therein. I'm currently carrying a full set of metric 3/8" sockets, plus 3/8" deep sockets, plus a full set of ratcheting combo wrenches. (Plus some overlap at both ends in 1/2" and 1/4" drive.) It's super convenient to be able to reach for the easiest way to undo a fastener, but I have to wonder how many jobs require one or the other that couldn't just be done slower with a different tool. For example, I'm 95% certain the only reason I have a 1/2" drive 21mm socket is for snugging up the leaf spring hanger bolts on the rear suspension, which is a job just as easily done with the 21mm combo wrench. (Which is also only in the kit for that purpose, I suspect.) For the smallest fasteners, I have 1/4" short and some 3/8" short and deep sockets, (and again the ratcheting combo wrenches). Probably don't need 4 different ways to turn a 10mm bolt, and I'm positive that there are no 5mm or 7mm fasteners anywhere, so having the "full set" on some stuff seems silly.
So my current plan is to at least try to identify redundancies and pull stuff out.
After that, I want to re-evaluate my jacking situation. Years ago, I switched to a bottle jack + Bogert Safe-Jack kit, plus the "jack stand" kit. There's a lot to like about that kit, but it's heavy stuff. I've since realized that with an axle-tube adapter I can do all of the same lifts with the factory scissor jack. I'm questioning whether the 20-30 lbs of bottle-jack-and-iron is justified vs. the factory jack.
What other methods can we use to identify crucial tools vs. "nice to have"? Any strategies for avoiding the "every tool in my shop eventually ends up in my van" issue? Is there any way to ID all the factory fastener sizes without going through the vehicle and trying everything? I have a digital copy of the FSM, but its up to use an old virtual machine and it hasn't run right since Windows 7 was a thing...
Great thread, thank you, I have been struggling with this topic for about a month now.
I will be watching closely.
