Midwest Rust Blues
Salonika
Monterror Pilot
Well I finally decided to finish replacing my rusted fuel lines. A couple years ago I switched over to nylon line from the fuel pump forward about two feet then kept the steel the rest of the way forward. It was finally starting to get very questionable. Check out my old fuel filter neighborhood. People out west unfortunately don’t get to enjoy these projects! If my Montero were an airplane I would have been grounded 10 years ago. I’ll post the after photos later. Amazingly the two bolts on the filter bracket came right off without even using any spray. I’m switching to Dorman quick disconnects. Can’t wait to get this done.
Side note, for a vehicle with serious off road and racing roots, I never understood why it appears zero effort was expended to protect the fuel filter. It’s hanging right out in the open really, even a piece of highway debris could take it out.
Salonika
Monterror Pilot
Frame is solid.......
I’m keeping the original bracket, I’ll blast it and paint it. It looks rough but it still has life left in it. The new filter diameter is a little smaller so I cut a piece of cooling hose to tighten it up.
Salonika
Monterror Pilot
Here’s the new setup with aftermarket WIX filter and Dorman quick disconnects. I now have nylon from the fuel pump all the way to where the steel lines come down from the engine bay under the truck. They weren’t rusty up there so I kept the steel in the engine bay.
The filter bracket is being painted so that will be installed soon.
Salonika
Monterror Pilot
All done! Glad to say goodbye to rusty fuel lines. Now I can change a fuel filter in about 2 minutes instead of an hour. Anybody else using these quick connects? If you are joining nylon to nylon you don’t even need compression fittings anymore. Just cut the nylon clean and press it in. They are almost too good to be true. After doing some research I found out many manufacturers have already been using nylon fuel line for a couple decades
b dkw1
Are those just regular push locks or something else?
Salonika
Monterror Pilot
This is my first time using them so I don’t know what a regular one even means.
Are you talking about the ones on the filter?
evomaki
This needs some more details/part numbers. That nylon line goes all the way back to the fuel tank? What is the size. Tell us about the nylon to existing Montero rigid line connection.
Salonika
Monterror Pilot
See: “What did you do to your Mitsubishi today” thread, my post #620 you’ll see the photo. Steel to nylon compression fitting, then yes all nylon forward to just below engine bay where again I have nylon to steel compression to change back to steel.
Salonika
Monterror Pilot
Also, the fittings are made by a company named SUR&R, and the nylon to nylon fittings are made by Dorman. I got both at my local auto parts shop. Both though are of course available on Amazon. I converted my return line to 5/16 at the pump so that everything was the same size hardware, but I converted the return line back to 1/4" at the engine bay because none of that steel was rusty. You don't technically need compression fittings on the return line since it is quite low pressure, if you've noticed, even Mitsu just used rubber hose with hose clamps in a few places along the return line route. I just happened to use a compression fitting on the fuel pump for the return because I didn't want to worry about that spot since it is harder to access if there were a leak.
oskarf150
