VanIsle_Greg
Managed to wrap up the cabinet doors tonight. After looking at the hinges again for a good solid 6 minutes, I realized that they are actually VERY simple to put in and to get correct. Measure where the overlap is for the upper and lower cabinet frame, mark a line, place hinge flush with line... screw in place. Done.
Finished. The keen eyed will notice that the far right handle has a hole in it. I tightened up the attaching screw from behind and it snapped off in the back of the handle...FML. I had to drill it out carefully. All of a sudden, the drill caught and went right out the front side of the handle lol. I still managed to drill and tap it out and get it installed temporarily at least.
in action
These work pretty well and hold the door in place reasonably securely. I think I will still install a proper stop of some sort... maybe.
Install pics for the handles, should have been easy. Should have been. Sigh.
Oh and look what showed up today... Lagun number 2! Box was trashed, so FedEx repacked it in another box... and that was trashed as well. All the hardware was rolling around inside the box and there was about a 5" hole in one end. Crushed top and on both ends. Man, someone having a bad day? This was the re-packed box!
Outside table? Hmm.....
Tomorrow is a write off so maybe Thursday for some more work on this thing. Need to grab a sheet of 1/2 ply to finish the bed, that is the next task.
in action
