FOR SALE: ACELA Monterra GL 6X6 with Total Composites 16' x 80" interior height box and Overland Explorer full build-out
twhit58
2018 ACELA Monterra GL 6X6 $329,000
This is the ultimate off-grid vehicle that takes you places other off-roaders can only dream about. Only 30k miles on this incredible vehicle that has spent its last 2 years in Baja and Alaska. Please visit Acelatruck.com to understand the detailed restoration process this truck was put through before being re-born as a full-time 6X6 Overland/Expedition vehicle. Need to 'bug-out" for awhile or just want to escape (un)civilization without sacrificing comfort? Here is your answer. Is there a stream or river between you and that pristine destination? Not a problem for this rig as it can ford up to 30 inches of water. Here is a rundown of some of its features:
EXTERIOR
GENERAL
[Acelatruck.com, Belgrade Montana]
Completed by Acela in December 2017
Ground clearance – 22 inches (highest in class)
Approach/departure angles: 40 degrees / 70 degrees
U.S. Army “Ultra Reliable” certification
Clean Montana Title in hand
Vehicle now located in California
POWERTRAIN
Original chassis - 2000 Stewart & Stevenson 1088A1, completely rebuilt by Acela in 2017 (visit Acelatruck.com)
VIN T012245EFMH
Caterpillar 3116 ATAAC 6.6 liter inline 6-cyclinder diesel engine, 290 hp, electronically controlled fuel injected, turbocharged and aftercooled, EPA certified
30,600 miles, 1887 hours
Allison MD3070PT 7-speed automatic transmission, electronically controlled WITH Power Take Off with WTEC II TPSS electronic pushbutton shift selector
Full-time all-wheel drive
Eaton CTIS (Central Tire Inflation System) pressure range 17-85 PSI
Dual voltage 12/24V electrical system
Rockwell dual circuit ABS Air brakes – Midland EL 1600 2-cyclinder compressor
Geared for 58 mph (2860 rpm); can be re-geared up to 74 mph
56-gallon fuel tank (100-gallon auxiliary tank available from Acela)
30-inch water fording depth
INTERIOR CAB
Comfortable seating for 3
Air-Ride driver’s seat – fully adjustable
29000 BTU/hr Air conditioning
47000 BTU/hr heater
Back-up camera
XM Satellite Radio
Full touchscreen audio system with speakers
Generous storage behind front seats
INTERIOR BUILD-OUT
“Total Composites” SS M1088 16-foot composite box, installed by Acela Truck Company in 2017
Interior final build-out done by Lite Industries, Red Deer, AB, Canada in 2018
80-inch (6’ 8”) interior height
Queen Bed over large storage cabinet with both interior/exterior access
Full wet bath on driver’s side
Thetford C220 Cassette toilet
Teak shower grate
North-South dinette on driver side, converts to extra bed
Powder coated aluminum cabinetry
Tern Overland Arctic Tern Euro Door Starboard entry door, roof hatches (2) and cargo doors
Passenger side galley
Dual Kona marine fans with USB outlets
Ceiling height refrigerator with lower cabinet
Tern Overland Artic Tern skylights and windows
Ceiling height wardrobe cabinet
Lonseal flooring
Nova Kool refrigerator RFU6200
Victron MultiPlus Color Control GX panel mounter over refrigerator
DC and USB outlets in galley
Flush mount Kenyon ceramic induction cooktop
LED lighting
Maxxfan skylight mounted over queen bed
AC outlets in galley
Garnet SeeLevel II water tank monitor
EXTERIOR
Aluminum retractable telescoping stairs
120-gallon freshwater tank with Whale Flo Jet pump
41-gallon grey water tank with Whale pump
Bullfinch external shower
Webasto hot water system with 2 air-to-water heat exchangers and fans for hydronic heat
4 Group 31 AGM batteries
Victron MultiPlus Compact sine wave inverter-charger with Color Control GX
Victron SmartSolar MPPT 100/50charger controller
4 x 125 watt (500+) watt roof-mount solar panels
Heater Craft Marine Heater
50-amp shore power outlet
Rear ladder to access roof
1UP 2” Super Duty bike/motorcycle rack
Fiamma F45s starboard side Awning
PURA ultraviolet water treatment system
Wilson 4G Omni-directional cellular antenna
Front and rear 12v electrical connection plugs
Cab roof rack recently added (see pictures)
NoSpin diff in both rear axles or just intermediate axle?
Total height?
Also, what’s the black box in the 4th picture down to the right of E-brake/trailer air?
03rubicon
Total height?
Below the E-Brake and Trailer air button, the black box with the three black buttons and the two red buttons is the CTIS controller. Central Tire Inflation System. Basically on the fly airing up and down of the tires for certain types of terrain.
To the right of the E-brake and Trailer is the standard AC unit which is a very expensive addition/feature to have in these trucks
Victorian
Awesome truck. Good luck. Feel free to send us an email with the specs and we post on our social media. Cheers
twhit58
Total height?
Total height is 12' 3"
Yes, the pictured
black box in the cab is the Central Tire Inflation System (CTIS) control unit.
Beautiful truck guys - where in CA are you located? My wife and I are considering building our own but saw this and may opt to buy one already built.
