Offgrid 4x4 Expedition Vehicle F450 Ambulance Conversion - SOLD !
dcrzach
Hello – My name is Zach Reinitz – I have built this Camper from the ground up over the last 8 months and am happy to announce it is ready for its new owner. This is my 3rd build and most extensive build to date. The Truck was designed around extreme exploration and ultimate comfort. With a proven global track record the Diesel powered Ford Superduty platform was our first choice. We acquired a low mileage 4x4 F450 Ambulance in Denver Colorado where we proceeded to drive the truck back to our shop/home in Reno and begin its conversion. The ambulance was stripped down to its aluminum core – Completely re–engineered/Cad Designed/ and professionally rebuilt into the camper you see today. Instagram Handle - AutarkyEV
Price - Reduced to 140,000$ Contact Zach at 775-200-3591
The Truck –
  • F450 Superduty Cutaway
  • 6.0L Bulletproofed Powerstoke diesel – Just rebuilt 3k miles ago from the block up by McDiesels of Reno and Tuned By Desert Diesel of Phoenix – New Heads, Complete Gasket Kit, HPOP, EGR Delete, Sinister Diesel Oiler cooler , Custom tune- all under a 30k/3 year nationwide warranty on all internal engine work. No DEF - Diesel 2/ biodiesel/ - no low sulfur required - ready for global travel.
  • 2003 , Single Cab, ambulance conversion
  • Purchased with roughly 85,000 Miles , Currently at 90,000.
  • Custom Vesuvius Grey Custom Paint with complete OEM plastics coated in Bullet Liner.
  • Total loaded weight is 12,800 Pounds
  • Total length bumper to bumper is 22FT
  • Total height is 10'8"
  • Fuel economy around 12mpg with loads of highway diesel power.
  • GCWR of 26000lbs. The truck is only 12,800 loaded. That leaves you with a 13,200lbs tow rating
The Drivetrain –
  • 4.88 Gear Differential
  • NV271F Heavy duty transfer case
  • Dana 60 Front Axle with Dana 130 Rear
Suspension, Wheels, Tires –
  • Atlas 4in Over stock Expedition Pack Custom built Leaf Springs front and Rear
  • Buckstop Designs Super Single lift components
  • Icon 2.0 Custom valved Shocks – All 4 corners
  • Bushcwacker Fender flares bullet lined to support 41in Tires
  • 20in 1st Attack Engineering “Super Single” Wheels
  • 41in Continental MPT’s Tires
  • Custom fabricated rear sway bar from Peavine Motorsports
  • Front Hellwig swaybar with extended Links
The Camper –
  • Full aluminum construction torsion free mounted Camper body – Rebuilt from original Ambulance Box - Interior height - 5ft 10in
  • 3m Thinsulate and Closed cell Foam complete insulation of floor, walls, and ceiling- Comfortable far below freezing temps and cools easily in Arizona heat.
  • Heavy duty insulated aluminum storage doors and entry door.
  • Marine Vinyl insulated woven flooring
  • Stainless steel diamond plated entry way / mud room
  • Hardrock maple interior wall panels accented in aluminum
  • All Custom lightweight Birch and Bamboo cabinetry
  • Isotemp Cruise 90 SS Marine 12v /120v fridge/freezer
  • Furrion Induction cooktop 120v
  • Under bed and inside dinette latching storage compartments.
  • SS Custom Shower Stall with Stoett Industries retractable shower doors – Also serves as vehicle pass-through to drivers cab.
  • Starboard Toilet stall with Thetford Cassette Curve toilet with Maxx Fan power vent and LED light
  • Dinette Seating with Teak Nautical custom table
  • Sliding aluminum and Birch bed platform. Extends to a very large bed slightly wider than a queen with full king-size length
  • Custom made memory foam Dinette cushions and mattress wrapped in easy to clean marine vinyl
  • Complete Lumicoin soft white touch lighting system with RGBW bed mood lighting flushed into aluminum trim accents on ceiling – with touchscreen controller
  • Dometic Heiki 3 Skylight – Bugshield and nightshade
  • 5 total Interior 120v GFI Dual outlets 1 with USB C charging
  • 2 12v USB charging stations
Armor and Recovery Gear
  • ARB premium Front full wrap winch bumper
  • Bullet lined Rear bumper with hitch receiver
  • Smittybuilt 17.5k front winch
  • 12k pound heavyduty exterior mounted recovery boards
  • Full aluminum diamond-plate exterior bash guards bullet lined to match
  • Tig welded, aluminum, powder coated above Cab recovery gear storage rack
  • Rear interior below bed mounted Fullsize Spare tire
  • Rear exterior mounted 4.5 gallon Rotopak
Lighting
  • Pair of Baja Designs S2 Pro floods on ARB mounts
  • Hella Rallye 4000 all metal Pencil Beam Halogens
  • Over Rack mounted 40in LED Light bar
  • Custom engraved aluminum interior control switches
Power System –
  • 640W Rec N Peak Rooftop Solar array
  • Victron 100/50 Bluetooth Charge controller
  • Victron BMS with Shunt – Interior controller
  • 3000w Compact Xantrex Freedom Inverter Charger with interior control panel
  • Midnight Solar Baby box with charge controller and inverter breakers.
  • 200 Amp DC disconnect
  • 30 Amp 120v interior accessible breaker panel containing all circuits both AC and DC in one easy to access and maintain panel.
  • 300ah Battleborn Lithium Battery bank
  • LifeP04 Battery Isolation Manager – Charges house batteries while driving / keeps truck battery charged
Water, Heat ,Cooling –
  • 50 Gallon Fresh water tank – SS marine inlets
  • 35 Gallon Grey water tank – 3in RV style outlet
  • Shurflo 12v Water pump and Shurflo macerator pump for shower .
  • Full Pex Plumbing
  • Isotemp 11 Gallon SS water Heater – 700w 120v and heated via the Trucks coolant while driving
  • All plumbing and tanks are mounted within the insulated interior and will not freeze while camper is heated
  • Diesel Eberspacher d2 Airtronics Heater with Pro touch thermostat Contoller. – has separate 3 gallon insulated fuel container
  • Turbokool 12v DC Evaporative cooler
  • Outdoor hand cleaning water Nozzle
Price – $140,000
Serious offers only! Contact Zach via call or text at 775-200-3591
Grenadiers
Beautiful truck! Do you have any pics of the bed framing without the mattress? Closeups of the install for example. We want to do the same thing in our Saurer. Current bed is too narrow. Thanks, Dave.
shellb
Echo what they have said, amazing job. Kind of want to bring this back to CO!
Anyone have a good RV financing company? Haha.
gdaut
Ad says interior height is 5'10". Damn complete, comprehensive, well documented ads make it hard to find specific information. Took me 3 reds to find the price.
Very nice camper.
  • Like
Reactions: zip
Jdubucsd
Addicted to Espresso
Thats a damn nice extensive build!! Legit! I bet people would also want to see electrical/battery pics
E
eugarps
Guest
Please excuse my ignorance on the Thetford Cassette Curve but how much of it must be removed and carried out the door in order to dump it? I’m familiar with the Thetford cassette units but not this one.
dcrzach
The top and bottom separate . The top contains the fresh water for flushing and the bottom contains the waste. Its a rather simple operation of unlatching the the top and setting it aside. The bottom has a large handle to grab and unlatches from the floor to be taken out and dumped - very easy . electric flush and never has odor
