Why yes, that is a Warn 8274 on a Wrangler JK
axlesandantennas
A few years ago, after purchasing my 2018 Shara JK Unlimited, I caught myself in a few spots where a winch could have come in handy. In talking to a few friends, it always came up "too bad you can't mount a 8274 to it". Well, ignorance is bliss.
I found a rough condition 8274 on craigslist that was not running but got it for a song. I spent a few evenings gutting it and putting it all back together. Mostly just needed to be cleaned. I did replace the solenoid with a newer single type. Only thing that needed to be replaced besides that was a few ball bearing that disappeared on the ground. The cover fort the solenoid was busted up so I made a new one out of some ABS I had. Got a 150 feet of new Warn steel line and drew up some plans on how to mount it. From what I can see of the serial number, it was manufactured in 1989.
My front "bumper" is a 5 inch C Channel that I built right after buying the Jeep. I got the idea of that from the J8 series. I looked around and found the correct mount for the winch from GenRight off road. My welding skills are just slightly better than booger weld, so I took the mount to a local shop and had them mate the holder to the bumper after I had spot welded where I wanted it. The spool is about 1/8 of an inch from the bumper, so not much margin of error. Since there is a little over lap in the front, I had the fab shop add some gussets to keep downward flex at a minimum.
The winch is hard wired into the battery but is air gaped by a 500 amp switch. I know a lot of folks run winches always connected, but I did not want every amp of the battery sparking around if I wrecked. In addition to the hand control, I ran a control switch along with a kill switch to the cab.
One thing that I knew I was going to have some issue with was air restriction to the radiator. I keep an eye on it and drive in a way that does not over stress the engine. On steep climbs on 90 degree days in East Tennessee, I can see the temp climb and then the fan kicks in. So far, it has not been an issue. I also make sure my engine is always free of dirt, which helps a lot too.
So far, I have pulled myself out of a hole once and a fellow traveler twice. I have also used it to demo my back yard utility shed and one at my parents house as well. Last year we had a down tree on the road by my house and after a neighbor got it with the chain saw, I pulled it to the side with the winch. It makes an amazing sound when working!
If I were to redo this, I am pretty sure I would fab the bumper in a way for the winch to set lower into the bumper. But as it is, I like it more than I probably should. And to be honest, I like the way it bring character to the Jeep since it looks like a complete anachronism.
pith helmet
I won’t tell a soul. Just something I’ve wondered about HD homemade bumpers as I’ve considered one myself.
ReconH3
Heavy Duty Adventurer
Definitely the best winch ever made. Mine has literally taken me all around the world. Glad to see you scrapped the 4 solenoid pack and swapped for an industrial contactor. Much more reliable. I run mine inside engine bay.
axlesandantennas
I've thought about it before as well. Sort of like those gigantic grill guards you see on F250 and such. I've never heard anything adverse about them as for the airbags. It is something that I thought about when I built it though.
axlesandantennas
I see you too are a fan of Khaki!
I had considered putting the solenoid inside, and still might, as yours looks better like that.
And yes, I am very pleased with the 8275. Having almost double the cable is nice for running blocks or having to change angle. My buddies have length envy for sure!
I was demonstrating it at an overland event a few years ago and when I hit the un-spool switch, everyone within ear shot turned their heads, haha.
ReconH3
That’s the factory Mojave Sand color. :D I love the ratcheting sound! It definitely makes heads turn. There’s a bunch of improvements you can do to make it more reliable. Like shimming the gears, tapping the main shaft and adding a circlip cover, securing the clutch lever with R clip since it pops out under heavy loads.
jadmt
ignore button user
there are no air bag sensors in the front of the jeep's bumper even on stock. You have crush cans but only two other bumpers I know of re-use those again and that is AEV and ARB.
axlesandantennas
Ah ok on the color. Mine is Gobi. It's not super apparent until you park them next to each other.
Vinman
Airbags are deployed by direction of travel and rate of deceleration, bumpers have nothing to do with airbags.
The only airbag module on Jeep TJ’s (not sure on the JK’s) are located on the transmission hump just ahead of the console.
jadmt
ignore button user
same place on a jk
darrylkd
