2021 F150 Towing Capacity Increase on some models
nickw
One of things holding me back on jumping into the F150 was wanting a 2.7 but it (for some reason) always had a lousy towing capacity relative to the others. I have a 5000 lb trailer but always wanted to option of upgrading to a larger heavier unit. In previous years max towing was 8100, looks like the bumped that up 2000 to 10100 which is a big deal for folks that tow and want a more fuel efficient daily engine for less $. You'll need the 2.7 payload package which comes with the 9.75" rear-end and option of 36 gal take also. Thought this was pretty cool.....
Todd780
OverCamper
View attachment 640465View attachment 640469
View attachment 640456View attachment 640460
Hmm. Very interesting. So does going with a 5.5" box effect the 10,100 lbs rating? Also noticed '2,100 lbs' is that a payload? I wonder if that would change on a super crew?
Would you happen to have the link where you found those figures?
Agreed. 95% of the time I drive the truck, it's unladen. So better fuel economy would be nice.
nickw
Looks like 1,965 for supercrew w/2.7 in XLT trim. Here is the info, just click the trim you are after, scroll down to 'Specifications' then scroll down for towing/payload:
2021:
2020:
Todd780
OverCamper
2021:
2020:
Thank you.
Just poked around that link. Hmm... looks like with the 2.7L payload package in a XLT Supercrew 4x4 w/ 5.5" box it would be 165 lbs more payload than my '15 and 200 lbs less for tow rating...
Guess than would vary based on options though.
Well that throws a wrench into my already muddled brain. Here I was thinking the next truck would either be a next gen Tundra or a HDPP F150 with a 3.5 EcoBoost...
Buddha.
Finally in expo white.
I don’t know why the 2.7 with payload package can’t have the same payload as the 3.5/5.0 trucks when they have the same rear axles.
D
Deleted member 9101
Guest
Yes, but for myself and like the OP, my trailer is only around 5,000 lbs wet.
Would a 2.7 Payload package do it? Probably. Would a HDPP do it better? Of course.
My lowely 2.7 STX with no kind of payload package would have no problem with it...so the heavier duty version wouldn't be a big difference. Where it's going to shine is the increased payload rating.
Todd780
OverCamper
5k lbs, a regular 2.7 (no PP) will pull it just fine. Like it’s not even there. Even with my old 6-speed 2.7, 5k wasn’t a problem.
But that 2.7PP might be the sweet spot. Gets you the MPG you want and the 7k GVWR.
Gotta drive a 2.7 and a 3.5 one of these days. I imagine with 3:73's they be quite peppy.
oskarf150
