GM fullsize AWD Van Info thread
Willsfree
Hello drsmonkey, I saw that "I've got Cognito UCAs for 1500 Silverado on my 08 awd van. "
I'm getting ready to order parts:
Cognito control arms and limiting straps; do you have part numbers and perhaps a pic?
I'm looking at doing Maxxcam torsion keys
Suburban 3/4 ton leaf springs
Bilstien shocks
Z71 Bump Stops
Any other recommendations for a successful lift?
What size tires were you able to mount?
Thanks
Scotty D
I have fiama and shady boy awnings for my westfalias but for my express I much prefer a tarp and shade cloth .
If you are creative, there are millions of different configurations for every possible scenario
drsmonkey
Bilstien shocks
Z71 Bump Stops
Thanks
Short answer. (but you should read the long answer)
UCA part number is UCAK100009. Straps are LSAK13. Our vans use the same UCAs' as 1999-2006 1500 pickups so any aftermarket UCAs' for that application will fit. For pics see the late December post from NWExpress in this thread. I am running 265/75/16's (about 31.6"), but I know others run 285's(32.8") with a little trimming. Even though you can fit 33"s, for me they compromise gas mileage, braking performance, and wear intervals of suspension more than I would like since my van is a daily driver. You may have to adjust your wheel offset to fit 33"s as well.
Long answer.
I likely understand suspension less than some, but definitely better than I can explain it. I took the time to write the long answer below for anyone looking to lift one of our vans safely (a lot of it applies to any gm front torsion, rear leaf spring suspension), not to say that anyone else is doing it wrong. I am not an engineer, just someone who has been building, breaking and wheeling lifted vehicles on and off for 30+ years. This is my first GM, so do your own research before taking my advice. If you don't, it is on you. If there are mistakes, missing info, etc. please feel free to let me know and I will gladly edit, but you may have to convince me first.
Below are some things to consider before lifting your van that may save you and hopefully others some money and increase safety. A lot of people buying these vans don't have a lot of experience with lifts and offroading, so there is a lot of misinformation floating around in this thread regarding lifts. Unlike most other trucks, there is not a lot of aftermarket support for our vans, and no turn-key solution available (except one that is over-priced and poorly designed) so it is important to understand the basics of suspension when doing your own lift. Two things to keep in mind when lifting a vehicle without going into extensive suspension mods...Everything in suspension is a compromise, and the engineers designed the suspension to balance those compromises to work optimally with some safety margins built-in. Moving the center of gravity of a vehicle up is inherently less stable, but it can still be safe if you know that and keep your lift within the limits of the suspension design.
Torsion keys = Before buying new ones crank the oem keys and see if you get the lift you are looking for without bottoming out...their seems to be a belief that what keys you use effects the spring rate, but it doesn't. A different key allows you to index the torsion bar differently and that is all. It is NOT equivalent to increasing pre-load on a coil spring. The spring rate of a torsion bar is static at a given load no matter where the load is applied in the travel of the suspension, and torsion bars have a relatively flat spring rate within their travel. Each one of our vans rolled off the assembly line with slight variations, so sometimes new keys are needed, but usually only when going for max lift (which comes with a lot of other problems.) Look at your halfshaft angles before you lift, it should be sloped slightly upward toward the hub. Post-lift your halfshafts should be sloping downward at no more than about the same angle. Much more and you will experience much faster wear of CV boots, tie rods, and ball joints. At extreme lift heights you severely limit down travel which can harm offroad performance and is dangerous on the road. Aftermarket keys allow you to adjust to the extremes, usually the OEM keys will allow enough lift while staying within a safe part of the suspension travel. Cranking torsion keys does not change the total suspension travel or where the top and bottom of the travel are relative to the frame, just the static point at which the suspension sits within the travel. By lifting the van you increase up-travel and reduce down travel available relative to ride height.
Front Bumpstops = You may or may not need them...the bumpstops on our vans are designed to act on more of the suspension travel range then "traditional" bumpstops. They act upon the suspension system through most of the uptravel cycle in order to give a more progressive spring rate. than a torsion bar alone. Because there is little to no uptravel before the bumpstop makes contact it also helps to control body roll reducing the amount of work the sway bar and shocks need to do. Look closely at where the bumpstops are located relative to the pivot points of the lever (lower a-arm) and the contact pad. You can see how much of the suspension up-cycle they affect. When you crank your keys you are moving the static point of your lower control arm away from the bumpstop which diminishes initial control of body roll. Z71 bumpstops moves the point of contact closer to the pad providing a progressive spring rate sooner. The compromise is that they will physically bottom out sooner and get rapidly progressive near the top of the travel, slightly limiting the total amount of travel. I have a hightop, travel in and live in really windy places with lots of wildlife, so I like the Z71 bumpstops for crosswinds or sudden maneuvers at high speeds.
Rear bumpstops = With the OEM leaf springs installed the bumpstops act much the same as the front ones, but because of the geometry they act on less of the suspension cycle than the front.. The stock leaf springs also have a relatively flat spring rate, but when you swap to suburban springs you have a stiffer spring with a much more progressive spring rate. The bumpstops move away from the pads, but because the spring rate is higher they are not as needed to control body roll but will still work on the very top of the suspension range as a bumpstop. I left mine stock to maximize wheel travel, but also added a rear sway bar for the same reasons I use Z71 stops up front.
Front Shocks = DO NOT USE SHOCK EXTENDERS, EVER! Cranking or changing the torsion keys to lift a vehicle does not change the total amount of suspension travel or where the bottom or top of that travel is relative to the shock. Those extensions only limit the amount of shock up-travel available to the shock. This likely will cause the shock to bottom out before the bumpstop, causing broken stuff. This is why the extensions almost always break when used offroad. The OEM shocks will work exactly the same post-lift as they did before. Neither the Bilsteins or the OEM shocks are position sensitive, so lifting does not effect their performance. As long as the shock has the correct OEM spec extended and collapsed lengths they will work. If your shocks are still functional there is no need to change them. When they die, or if you want a stiffer ride then it is worth getting the Bilsteins. The 4600 and 5100 series of Bilsteins only differ in finish and valving. The 5100 are valved more aggressively and will give you a more stiff ride feel.
Rear springs/lift blocks = Swapping your rear springs to 3/4t suburban works to increase ride height, spring rate, and travel. It also changes the front to rear balance of the suspension and makes the van ride more like an empty truck. It does unbalances the ride a bit. A custom leaf spring built by a good shop for your load and use is the best, and most expensive option. Lift blocks are an OK way to go if you want to keep the same ride quality, but only when the blocks are minimal and designed for the proper pinyon angle.
Rear Shocks = When you swap springs you have effectively changed the spring rate and the total amount of suspension travel significantly. You will need new shocks sized appropriately in order to not limit down travel. The Bilstein suggested in previous posts work. Lift blocks change the distance of the lower shock mount on the axle relative to the upper shock mount on the frame. Longer shocks may be needed to not limit droop, but I have not measured this to be sure that the OEM shocks wouldn't work.
UCA's = I would adjust your ride height (lift) first then get an alignment and see if you get sufficient caster (3+ degrees) without compromising camber. Every van is slightly different and you might get lucky and not need the Cognitos. The higher you go the more likely you will need a way to correct caster. The ball joints in the Cognito UCA's wear out about twice as fast as OEM for me, but they are also much easier to replace. The other reason to get aftermarket tubular UCA's is for tire clearance at steering lock. My 265's did not contact the OEM UCA's, but it could be a problem as tires get bigger. Downside is you will have to pay for a second alignment if you end up installing aftermarket UCA's.
Limit Straps = Mandatory with aftermarket tubular UCA's. The down travel on our stock suspension is limited by the UCA contacting a metal pad attached to the frame. If a tubular UCA is allowed to limit down travel in the same way it will bend and/or break. This could lead to sudden, catastrophic re-alignment of your front wheels at high speeds, which is no fun for anyone. The way I mounted my limit straps (drilling through the shock tower like Cognito suggests for pickups) is not ideal for shock life, see NWExpresses pics for a much better solution.
Willsfree
Thank you drsmonkey for the helpful and detailed post about the AWD suspension. This is the kind of information that will guide me to improve my van's height and handling. I will be hauling a sub-300 pound motorcycle with hitch carrier, swingarm too. This is why I was considering the Suburban leaf spring swap for extra weight, but I could also add air bags for that occasional load. Sounds like I should first see how much lift I can get from the OEM keys and proceed from there. I appreciate the explanation of the control arm/limit straps and shock lengths too; It's going to take a few more reads to fully comprehend the variables of this post.
boardrider247
Weekend warrior anarchist
Long answer.
Rear springs/lift blocks = Swapping your rear springs to 3/4t suburban works to increase ride height, spring rate, and travel. It also changes the front to rear balance of the suspension and makes the van ride more like an empty truck. It does unbalances the ride a bit. A custom leaf spring built by a good shop for your load and use is the best, and most expensive option. Lift blocks are an OK way to go if you want to keep the same ride quality, but only when the blocks are minimal and designed for proper the proper pinyon angle.
Thank you for that.
I went back and edited the lift post on the first page to include this.
Fc3434
I popped a transmission cooler hose and lost a ton of fluid on a slow residential road a couple weeks ago. I’ve replaced the hose, but what transmission service should I look at? Prior to this mishap I already put a new filter and done a full replacement (~13qts using the transmission cooler hoses) of fluid with Maxlife ATF.
after running basically dry, should I do a filter and clean the pan again? Or is just making sure the fluid level is good ok?
truckee travelers
I've got just over 100 miles on the new 4.11 gears now. I just took a quick drive after using HPTuner to re-calibrate the ratios and tire size. ABS and speedometer are working correctly again.
HPTuner ended up costing $450 after licensing, has a steeper learning curve, and runs the risk of bricking your ECM. I would only recommend it over the hypertech if you are planning other mods in the future that would require reprogramming.
I'm still in the break-in period, but once I get 500 miles and a fluid change done I'll be able to get in the mountains with my sled trailer and report back. I can't wait until I can get a full WOT from a stop to feel the difference.
My initial impression is that 4.11 are just about right for 31-32" tires even in the mountains, and that 4.56 might be too low if you are logging significant highway miles.
Thanks for the update. I'm going with 4.11 based on the info. you provided and the shop's recommendation. Getting it done in a few weeks so pretty excited. Still a little concerned about the t-case and slight difference in front vs rear that you referred to. The shop seemed to think there would be no problem.
drsmonkey
I'm 500 miles into the 4.11's now, fluids changed and everything still working great. The viscous coupler is still working correctly so far. At worst right now I'm thinking that maybe the coupler might just wear a little bit faster. I hope there is a certain amount of leeway is built in to allow for some stagger between front and rear tires and that the difference in gearing stays within that leeway. I do think that it is more critical to keep tire wear and pressure even to keep the coupler working.
I'm still working on figuring out exactly how to do it and test my theory, but I plan to try manipulating tire pressure a little to make the effective rolling circumference of the front and rear tires compensate for the slight difference in gearing. First I'm not convinced it is needed yet, and second I want to be pretty sure that I'm not accidently accelerating wear by screwing up the math. If I get to the point where I'm positive it is worth the effort and reasonable assured it is effective I will post the results. Same if the coupler blows up.
I've gone over a couple of our smaller passes and cruised at 70mph now. So far the change is subtle, but my past experience with re-gearing has been with underpowered rigs on bigger tires (4 banger manual trans Toyotas and Jeeps running 35-37" tires) so my expectations may have been too high. The torque of a v8 and auto goes a long way to make up for a lack of gearing, even on a relatively heavy rig.
Spring Break and the annual trip to the dessert is coming up, so I'll be able to see how it does fully loaded at interstate speeds and offroad soon.
pwilk
This thread has been a huge help in researching lift options for my van, thanks to all, in particular @drsmonkey lately. I was close to just dropping the money for the Boulder Offroad kit, but have decided to piece it together myself for significant savings.
My question is with the #22-907 suburban springs, will new longer U bolts be required? If so I'd like to order them at the same time as the springs. General Spring makes custom sizes so if new bolts are needed if anyone can recommend the length it would be appreciated.
Fc3434
Well it turns out there was probably something wrong with the transmission pump that blew the hose off even though it was clamped. Went for a drive today and got the dreaded "rev but no go" in all gears. Dipstick reads a couple quarts high (pump not pushing fluid into the radiator/cooler would mean there's more in the pan).
So......I'm in the market for a rebuild. I'm going to go all in and get as bulletproof a transmission as I can afford. I come from a Toyota 4Runner and the thing I loved most about it was the reliability. I had no qualms jumping in and going on a 2,000 mile road trip. I'd like that kind of reliability out of the Express ( I know I'll never get all the way there) and the transmission being the weak link of the drivetrain seems like the best place to spend a little money.
drsmonkey
You will need longer u-bolts. I don't remember what length I got, but I do remember I cut them shorter after installing. I just measured mine and they are 9" long. For custom bolts you will also need the type of bend, diameter, and the inside length which will all match your existing bolts.
truckee travelers
Got the 4.11 gearing. Driving up 80 from Reno to Truckee and seems to be nearly perfect. Only downshifted twice from drive 2 times while maintaining 70. I agree with your assessment that 4.56 gearing would likely be too low for interstate cruising. My problem now is that the speedometer is 10mph too fast. I looked into the Hypertech 752501 and looks like it's for Chrysler vehicles? The 732501 is for GM but still unable to confirm it works on a 2014 GMC Savana. Any input would be appreciated.
Ancientsojourners
