Best quality replacement LR3/4 front lower control arms
Buying an LR4 that needs a new set of control arms. 100% doing the entire arms, not just bushings. Definitely doing new hardware.
What are the best quality aftermarket replacement arms? Looking to do light off roading and beach, mostly street and highway. Would prefer something that will last me another 50k at least.
Meyle HD - These sound promising. They claim to be better than OEM, $300/pr + $50 Hardware
Lucky 8 with orange polybush - $358 with hardware
Lemforder - $380 + hardware
Lucky 8 Regular - $230 <- These sound like the worst quality
tdhunter13
Hey Man,
I have an '08 LR3 and used the below arms back in late 2016. Have about 70k on them currently. Do note that these are Range Rover Sport (RRS) arms which are the same but supposedly use heavier duty bushings and are used in some armored LR3/LR4's used in the UK (if I remember correctly). Also, I use Land Rover Merriam to price match parts on Atlantic British. AB is very good about price matching and have very good customer service.
AB RRS Genuine Left
AB RRS Genuine Right
Land Rover Merriam Parts (Price Match)
P.S. Here is a thread I started when I originally did all of this, hope it helps!
LR3 Control Arms
Thanks,
Tyler
gabrielef
I’ve heard about this but completely forgot. I might want to try OEM again sometime and this would be a great option. With all the weight I’m hauling around, it’s be nice to have heavier duty OEM bushings.
yubert
I would skip the orange polybush bushings. I do a fair amount of offroading, along washboard roads so when the OEM bushings wore out, I replaced them all with orange polybush. My rear UCA eyelets broke a few years later. I found out I wasn't the only one that suffered broken control arms. If you look at the European forums, they recommend OEM rubber or Meyle HD. They believe polyurethane is not as forgiving as rubber. However, Atlantic-British has complete UCA with green polyurethane bushings. They're supposed to be softer than the orange so I went with that. It's been 2 years and no broken eyelets.
gabrielef
Oh wow. I’ve heard the same too. I have orange poly’s in my LCA’s only. Everything is else is OEM. Wouldn’t mind trying green or Meyle HD though.
Superpro make specially engineered bushings for the front Lca
I had full Superpro set on my Defender 90 and LOVED them.
I am very much considering this way to go.. I just wish they sold arms without bushings for them to go into. My fear is I buy the Superpro setup plus Lemforder ball joints plus new hardware which is about $300. Then we go to pull old arms and they need to be cut out, don't have arms on hand, then need to buy new arms ASAP because truck is stuck on a lift with no arms.
Otherwise I think the Meyle HD are standing out as the best "value" at about $350 for the pair, assuming they hold up.
Hey Man,
AB RRS Genuine Left
LR3 Control Arms
Thanks,
Tyler
Thanks for that. Very tempting but nearly 2x the others...
Michael34
I think Brit part sells the Lca without bushings
DiscoNels
After owning my LR3 for the last 8 years and trying different arms and bushings. I would have to say stick with the Meyle HD, or go with RRS arms as @tdhunter13 stated above. Stay away from Poly bush all together whether it's the stiff Orange or the softer Green. They simply aren't flexible enough to support the heavy weight of the LR3/4 models and cause cracked arms. I installed full orange Poly all around on mine and have been replacing with stock items as the arms crack. So far, both rear uppers and recently the front lower left.
I also have a friend who purchased a used LR4 in 2020 and installed brand new AB arms with green polybush and found out he cracked an arm when we were out in Moab in September. Not even 3 months old with less than 5k miles on them.
This was my latest front left lower arm failure, as you can see the collar around the orange bushing is completely gone. I loved the stiffness of the polybush on road, but failure is not an option when out on the trails.
Shigeta
W6EXP
If anyone is interested in the OEM parts without paying Land Rover prices, I was able to cross reference the Land Rover part number and find the Lemforder part number.
(For those who don't know, Lemforder is the supplier (OEM) of control arms and sway bar end links for the LR3.)
Note: These are LR3 part numbers, not RRS. I attempted to do the same exercise for the RRS arms, but couldn't find enough information about the cross-compatibility to feel confident in going RRS arms.
Front Suspension:
PartQuantityLand Rover Part #Lemforder Part #
Lower, Right Control Arm1LR028245211460
Lower, Left Control Arm1LR028249211459
Upper, Right Control Arm1RBJ5002223822701
Upper, Left Control Arm1RBJ5002323822601
Sway bar end link2LR0141453671101
Rear Suspension:
Lower, Right Control Arm1LR0515924007201
Lower, Left Control Arm1LR0515944007101
Upper, Right Control Arm1LR0516223993901
Upper, Left Control Arm1LR0516233993801
Sway bar end link2RGD0003122959201
Looking at my receipts from a recent suspension refresh, I paid $1278.39 shipped from Trodo.com back in October 2020. I bought bolt kits from AB, but otherwise everything came from Trodo—the only supplier who I found who had all of the Lemforder parts.
Michael34
Hey Man,
AB RRS Genuine Left
LR3 Control Arms
Thanks,
Tyler
Any idea if it the bushings are just better or is the actual control arm stronger structurally ?
tdhunter13
lll
Fair enough. Looking back through my receipts and emails, I price matched the arms at about ~$270 each which made it more reasonable. Also, the MOOG or Mevotech option in the below link may be worth considering.
Going through my old thread and comparing on Rock Auto, it seems the bushings are just better. You can find some of the Lemforder bushings below and they specifically say 'Armored Vehicle'. Also, when cross comparing full front lower arms between LR3 and RRS, I do not see any part numbers that match up. Which leads me to believe the bushings are better (or at least different) since we know the physical arms fit between the models.
Generally not a big Rock Auto fan, but they have a rather decent selection across the board for LR3 items.
Rock Auto
Joseph McCormack
