Moby 1 XTR Off Road Teardrop Camper Trailer
Gride7
2013 Moby 1 XTR
Asking $25,0000
This Moby was purchased/built with everything that was offered
Fully loaded it weighs about 2500lbs
AEV rims
BFG KM2 35” tires
Custom built roof rack that currently holds the roof top tent but can be used for anything you’d like to attach
Propex Forced air propane heater
Propane heated hot water
Led lighting throughout inside and outside
Detachable outside handheld shower head w/ hot and cold controls
Stainless 13x17” sink w/ fold down faucet
Cook Partner 22” two burner stainless cooktop
Engel MT60 ac/dc fridge/freezer (120v/12v)
2-12 volt 105 amp/hr AGM battery pack with a 10 amp dual battery charger
Shore power and 12v charging system
AC shore power has 3 outlets (1 in battery box /1 in cabin/1 in galley)
Small flexible, roll up solar panel for tending the batteries
Individual folding memory foam mattresses that fill the entire inside
5000btu Air conditioning unit inside that runs off the generator or shore power
Hannibal 1.6 jumbo tour roof top tent with 3 sided enclosure that sleeps 3-4 (adults/kids)
Hannibal 2.4 awning with 3 sided enclosure measures 10’L x 16’W x 7’H also has four screened windows and a door but you can also just use the awning without the sides
13x18” Roof vent w/ screen in the cabin
Multi Axis Coupler -Max coupler/lock n roll hitch
36 gallon aluminum water tank
Expedition box 48w x 30h x 14d
Shore power pigtail
Independent A trailing arm
3500lb axle-less spindles
Electric brakes
UPDATES MADE since purchase
New style doors installed by Vorsheer (Moby) in October 2019
Brand new hot water heater installed September 2020
Replaced all of the brass quarter turn valves, elbows and fittings September 2020
Original price from Moby was $43K
josh8667
I'm going to be in SLC the weekend of March 6-7. If you still have this in 2 weeks, I'd like to come check it out.
Gride7
Sounds good. Private message me when you come out and I will send you the address where it is located and my number.
PNWav
