2013 Moby 1 XTR
Asking $25,0000
This Moby was purchased/built with everything that was offered
Fully loaded it weighs about 2500lbs AEV rims BFG KM2 35” tires
Custom built roof rack that currently holds the roof top tent but can be used for anything you’d like to attach Propex Forced air propane heater Propane heated hot water
Led lighting throughout inside and outside Detachable outside handheld shower head w/ hot and cold controls Stainless 13x17” sink w/ fold down faucet Cook Partner 22” two burner stainless cooktop Engel MT60 ac/dc fridge/freezer (120v/12v) 2-12 volt 105 amp/hr AGM battery pack with a 10 amp dual battery charger Shore power and 12v charging system
AC shore power has 3 outlets (1 in battery box /1 in cabin/1 in galley) Small flexible, roll up solar panel for tending the batteries Individual folding memory foam mattresses that fill the entire inside 5000btu Air conditioning unit inside that runs off the generator or shore power Hannibal 1.6 jumbo tour roof top tent with 3 sided enclosure that sleeps 3-4 (adults/kids) Hannibal 2.4 awning with 3 sided enclosure measures 10’L x 16’W x 7’H also has four screened windows and a door but you can also just use the awning without the sides 13x18” Roof vent w/ screen in the cabin Multi Axis Coupler -Max coupler/lock n roll hitch 36 gallon aluminum water tank Expedition box 48w x 30h x 14d Shore power pigtail Independent A trailing arm 3500lb axle-less spindles Electric brakes
UPDATES MADE since purchase
New style doors installed by Vorsheer (Moby) in October 2019
Brand new hot water heater installed September 2020
Replaced all of the brass quarter turn valves, elbows and fittings September 2020
Original price from Moby was $43K
Asking $25,0000
