Show me your Ammo Can storage
Outdoorsben
Curious what you guys are using them for and where you mount them. I had two mounted in the back of my JKU but with the fridge I moved the mounts. I have an air compressor ammo can and a tool one but curious what others are using.
tx-jeremy
I’d like to see any pics of the air compressor. I’ve been stewing about where to put one
Outdoorsben
This is a stock image of what it is.
NatersXJ6
50 cal cans on custom mounts on each JKU wheel well. One has winching stuff, the other has fluids, epoxies, etc. EDIT - added a photo at the end.
40 mm can on top of my spare tire carrier has tow strap and jumper cables.
Note, having these was a PITA at the federal security checkpoint for the Hoover damn. Between these and pelican cases, I was inspected for longer than I looked at the dam.
Air compressor under passenger seat. Also custom mount.
85E07FD9-A3D6-494A-8EF5-EE8477E6AD74.jpegB844D7F3-A222-4D05-924D-6C36940E1A85.jpeg291BC4E2-F58C-4629-9CE4-E55A3382DE9D.jpegCFDD868A-3D81-4FE9-BE45-939D16E5760E.jpeg2E4272D6-20C2-445C-BFF7-67A899ADF4FE.jpeg
jscherb
WSS
Rock Stacker
One is fluids (diff, T case. Eng oil, brake fluid and ATF) The second is parts (belts, elec hardware, nuts & bolts, brake line, etc)
