Timing Belt Question -Help
Buddha.
Finally in expo white.
There’s a tensioner that you took off and put back on?
Did the belt seem tight? It should be.
Did you double check the alignment marks were still correct after turning the engine over by hand.
Buddha.
No seems to run smooth, no malfunction lights are lit.
Should I let it run a bit?
If it’s a sound that’s wasn’t there before I would guess there’s a problem.
Maybe take the timing cover off and inspect the timing set for wear.
I’m not sure what it would be.
Buddha.
this is from your other thread, and I don’t know what he’s referring to but it’s not this is it?
Another thought, there is a small metal pin that holds the crankshaft gear in time. Don’t mess that up. I accidentally drove that pin into the gear and had to replace the whole thing. Search my username on here and you’ll find a few threads related to engine rebuilds and timing belt jobs. Don’t do what I do, learn from what I’ve done so you don’t make all the same mistakes:)
zhukoveli
