Lets see some full size pictures...
Regcabguy
Oil eater.
ACtC-3cqzED9r5pyDn0g0Ed_9tg5UPAxUA6qOwp0s7726l-QDs9EpAO0BfiAlpFy29XMw7zkbLypqPtdD-qO79Cx_-0iN28lwyTz2_WgmDNz-xa3E-Kf_QqD6vRMlkkZWG7cGbpbu6ICoRhoxKtWBoeXXdUXZw=w1372-h914-no
ACtC-3dcfCdM1IZHFPUQ4MopC5OMybgdaREDweFMXjBIYgh6MWKT-EoBCaxGxV6nLl8IHSu1B4hs0UB4SifCRf1H9mRzaEJAElxmjT1-caslYkMKllVTJgZ7HH5TuviVEqooG-9W8BxlnfLNOiiLJSS1uIXnIA=w1372-h914-no
Time for a flatbed Bundetec.
MattF350
Got the oil changed, boots rotated and a checkup. Free wash to rid of the salt!
Chris W
Def a nice truck, but seriously... is there a reason why that tray is set so high?
Its high for sure, 2 main reasons are the 4ft drawer out the back and 20 liter water tank. All is sitting above the fifth wheel mount. I’m waiting for a camper so it’s livable for now loading stuff is a nightmare, I need a loading dock at my house.
Regcabguy
Oil eater.
Truck and engine:
02 Super Duty CC Lariat 4x4 (REAL floor shifter W/lock out hubs), 7.3L Diesel, ZF 6 SPEED w/LUK clutch & South Bend Kevlar PB, DP Tuner- Stock HP,40HP,60HP,80HP,120HP,140HP, 1.15 A/R NON Wastgated Van TURBO with ATS housing, and Non-EBV Turbo Pedestal, ITP Over boost Pressure Regulator, Crank Case Vent mod, 4" DPPI down pipe, 4" custom mid side exit straight pipe (before the rear tire), Tymar open intake, Dana 60, 3.73 gearing LS,
Exterior:
IH T 444E BADGES, 06 red Grill, Ranch hand bumpers front and rear W/skid plate, 3 step N-Fab side bars, 06 heated TT mirrors, Mastercraft 35" MUD tires on Helo Maxx 16x10 BLACK RIMS, Superlift 5" LIFT, ARE Z Cap with 4'x5'x6" Con Ferr Roof Rack, 35" spare roof top mounted, Bushwacker Fender Flares
Interior:
Auxiliary Idle Controller, Excursion center console w/Wood & Rear Radio Controls, Triple A-pillar Gauges, Rhino Lined light gray(not black), Garmin GPS 12map, Uniden CB, Husky floor liners (custom cut for 6 speed), Wet Okole Waterproof Neoprene seat cover rear and Smittybilt G.E.A.R. seat covers front, Norcold 60L fridge
Dyno:
320 RWHP and 700 RWTQ with 35" tires before new turbo
MPG
17-22MPG depending on load
Louie!
My friend has a 2000 F-250 Supercab 7.3 4wd with a cab high Snugtop shell,auto with Banks Trans Command,torque converter,chip air intake turbo Banks Big head wastegate and 265's. 265's. Stock gearing. $7K worth of Banks stuff on their and has never gotten more than 16 mpg. You're getting better mpg and probably didn't spend as much.
Storz
Those washer tubs are popular in Anza Borrego. No fires without complete containment of ashes.
I really like it, its a Solo Stove 'Bonefire'
Burns hot, and leaves absolutely zero trace of anything on the ground. I found out that the 18" Komodo half grill rack will work on it as well so we dont have to prop up our cast iron pans with logs anymore haha
Regcabguy
Oil eater.
I wasn't aware of it. Great product. We have to have a fire. Thanks.
dave1014
Got the tent mounted on the new truck last week and set up at work the other day for fun
V45W_Proto2.5
