Starting over again for the last time 2016 jku rubicon hard rock
Smileyshaun
Hi my name is Shaun and I have a bad case of vehicular ADD . I have bounced around from vehicle to vehicle for far to long , always finding flaws in one form or another that would have me buy a rig build it up drive it for a while then eventually sell it , sometimes for a profit , sometimes break even . And it has been fun and had a lot of good times doing it but the cycle just got old. Probably talking well over 40 rigs . so I finally decided to buy something new enough to have a warranty.
No name yet and no big plans for build , switching most my camping gear to more backpacking style to keep things light and compact as possible. Stay tuned for adventures .38D9D20F-921F-423D-9092-B618B7C3ED73.jpeg
Smileyshaun
First upgrades are minor but necessary
Some seat brackets
3/4” spacer lift (probably put a 1” in the front after a winch )
And some upgraded bumpstops .
And that will be it for a while ....... probably4A02C4BA-BEA4-4429-B791-7B223A5D615C.png92038C1B-6E2C-4574-B64F-2CEFC843F07E.jpeg970F7886-2D26-4943-9763-FEC4F99AD1B3.jpeg
Smileyshaun
Definitely need to swap tires here soon .For one I don’t care for toyos or MT tires for that matter and I could use a few less rpms on the freeway to probably gain a mpg or two 798CF9C4-23CF-4FCD-B9C8-DCF5BF7E8FA9.jpeg09CC2CC9-00AB-4066-861B-366F3429CEB0.jpeg
Smileyshaun
Took a little camping trip with the munchkin to the coast And stopped on the way at a place called triangulation point normally has a wonderful almost 360° view but as my normal luck with your points is the clouds were a bit thick that day. C17F0116-6FC6-4755-9A8F-01EA873B7709.jpeg
Also re-learn you should always walk a spur trail before you drive up it just in case it only goes to the edge of a cliff and stopsB63087D9-3DFD-496A-AC65-122CE776A21A.jpegE79D3E94-C9BC-43CE-98E6-0BC7C9691026.jpeg
but the drive up was nice with wildflowers in bloom
Smileyshaun
I needed a way to separate some camping gear so b4 we left I whipped up a quick shelf . I’m sure my neighbors were happy with me running power tools at seven in the morning .
9AAB3AEF-B247-4E04-ADEB-BCF90A475887.jpegE8239267-CA8B-4ACB-9BB1-12C8CE56E915.jpegFF5FCDA8-388B-48F1-B315-F31D9C2ED903.jpeg
wandererr
Nice shelf setup! I built something similar couple years back and it worked out perfect (at least until I picked up a small 12v fridge ;) - now I need to reorganize the back a bit). I tied mine into the jeep though by drilling holes and using longer hard top bolts.
Smileyshaun
Went with the fiancé to do a wine pickup out in mosier Oregon on the gorge and took the long way there over mount hood and down some FS roads and where rewarded with some fantastic wildflower blooms and views mount adams . On the way back from the winery we tucked down some more backroads and found a great place to eat some kabobs with a view . 2A3986F3-8045-47D3-8CE4-047B07FD5BFE.jpeg4AC48BB4-F070-461F-8391-4825D2C35F54.jpegB359209E-7B52-4DA8-A77F-AE59AF07E06B.jpegF64B0123-0D58-4F86-AC86-5052BBA6A6C4.jpeg342C7750-A3D1-426F-965B-7B3FDDDF632F.jpeg
gp01
