palebluewanders
Been a while since I browsed this forum but very cool to see your updates! You even updated the name, so long Gertrude. :)
			hello, as long as the truck is in europe, I could offer you a conversion at our facility in Germany, 4wheel24. Please find attached a similar 1120. We do expedition truck conversion. Contact me with any questions you have. We do this 10+ years and build 130+ trucks. Thanks Martin
I am based just outside of Bergen.I spent all day in Oslo today kicking my heels waiting for the results of a Covid test so I could go to Sweden.Hit me up sometime when you are over here,plenty of space to park up overnight.
- Do we need to uprate the shocks holding the cab to handle the extra wheel weight? The drivers cab is designed for 6 people so i assume this will be OK to have another 15-200kgs on the roof while it will be mainly 2 people driving..
As far as the power bump, I am also looking into doing something. Another option I learned about on the German LN2 forum is replacing the turbo with a more modern one from a later generation Mercedes. My turbo doesn't build much boost in the lower RPM range due to design. A slightly more modern turbo will build more boost lower and a bit more overall. The conversion is supposed to be fairly easy and the parts are about $1k.
Pretty typical layout, although large! With enough solar you will only need the alternator power occasionally, I would not expect a second alternator will be needed. As long as you use a battery to battery charger you can control how many amps the batteries draw (to protect the alternator) and shut off alternator charging when not required.
Thanks Joe, the size of the inverter and bank is mostly due to the induction cooking. But when you refuse to do gas/lpg that is how it is. I might even "need" the Multiplus-ii 5000w inverter...But they start to get big, heavy and expensive really fast.. I promised myself I would not do a full Victorn setup, but here I am..
Regarding DCDC charger, the victron smart unit I think has programable cut off and kickin charge voltages, so it is only designed to charge when the motor is running keeping the starter batteries at a set voltage. So I think it should be safe? Or I am probably overlooking something. Another thing I wanted to look at was to add a way to charge the service batteries from the house bank in an emergency, since I am running 24v it should be pretty easy I thought...
