Trying to get an idea as to what I can sell my 2500 Suburban 8.1L Whipple Supercharged vehicle for
grey2112
Apologies if this is not allowed, but I am new here and am trying to an answer from the experts here.
So, realistically given miles, conditions, features (the 8.1L engine with Whipple Supercharger) what could I expect to get for this if I sold it?
Off the bat - has an 8.1L 496cc with an added Whipple Supercharger - 600+ HP and 647 ft-pounds of torque. It is a towing beast. You do have to use 91 octane fuel.
4x4
LT trim, I think
No crash history. I bought it from the original owner - he put 209,000 mostly highway miles on it towing a big Toy Hauler all over the country and Canada. I have put 2000 miles on it just towing the boat to and from ramps and occasionally to work - so 211,000 on it
Never smoked in.
Condition outside is OK - could use a paint job to pretty her up as it is peeling in a few places.
Inside condition is sort of OK - a few small tears and rub spots on the leather seats, and the top of the dash is sun-cracked so I have one of those carpet covers on top of it. CD player doesn't work but the stereo itself is awesome and I use a Bluetooth MP3 device to stream my music from my phone.
There are a few "empty holes" in the center of the dash where a CB radio and some other piece of electronic add-on was - I think a DVD player. I'm sure it could be covered or something else installed there.
Driver's control panel (where all the buttons for locks, windows, etc.) is loose (broken clip) so I have some duct tape there holding it on - again, something a new piece with usable retention clips could fix.
Headliner in only one place sags a little but nothing serious - it is the moon roof.
The rear view mirror suddenly let loose of the glass a month ago - weird. I tried gluing it back in but no luck. So I replaced it with a suction cup one. I also have a rear camera/front dash cam installed - it is awesome for backing up, hitching up, etc. and runs all the time, so I have been using it as my primary rearview mirror when driving - I like it as I can see a lot more on the sides - I hardly ever look in my side mirrors when changing lanes because of it.
The side mirrors are different - one is factory with power and the turn signal, but the driver's is manual.
Class IV trailer hitch with ball included.
No third row seating so there is a VERY large cargo area back there with a plastic heavy duty cover down.
Runs great - ice cold AC. The only niggling little issue is a very slow oil leak somewhere - if I were to guess it may either by the pan gasket or master cylinder gasket. I put some "stop leak" in it and it helped, but it is so slow that simply checking the oil level every month or two and adding a little oil (like maybe a half quart) seems to be working just fine. These engines are known to slowly lose oil (burn or tiny leaks) especially after 200,000 miles of use. I use 25w40 and it helps keep that to a minimum.
All the things I have done to it:
Alternator - Sep 2020 (lifetime warranty)
Battery - Sep 2020 (3 year warranty)
4x4 actuator motor replacement - October 2020
New serpentine belt - Aug 2020
New E rated tires - May 2020
Cooling system flush, new thermostat, idler pulley, water pump, belt tensioners, spark plugs - August 2019 (when I first got it - had a mechanic really do a huge inspection and replace everything he thought it needed to be safe)
Starter, power steering pump, HP lines - December 2019
Special "racing" spark plug wires - $275 alone for these - done to keep the heavy duty cast-iron engine block from melting normal spark plug wires. April 2020
Ball joints, pittman arm, idler arm and bracket, brakes, CV axle, control arm - basically an entire new front end - and a front end alignment - Aug 2019
New catalytic converter, exhaust manifold gasket - Sep 2019
In July of 2017 (original owner) the transmission was replaced - truck had 192,129 miles on it - so the transmission is 4 years old and has less than 20,000 miles on it.
April 2019 - Instrument cluster replaced
I have ALL of the receipts from both the previous owner and myself, including the original bill of sale listing all options.
I am hoping the incredible towing capacity (12,000 pounds) and all the new parts and work done to it will be a good match for someone that can't afford or doesn't want a diesel.
Not in a rush to sell it so I can afford to wait for the right buyer to come along.
Thank you.
grey2112
Located near Tampa, FL
I don't understand what "salted steel" means?
No oil analysis - where can I get that done and why would that be important?
Mickey Bitsko
Have you looked at the blue book or nada values? Not that it matters anymore,
Maybe take nada average value and triple it. Start there.
grey2112
It appears that right now there is a huge shortage of heavy duty tow vehicles, at the same time as there are big boats and travel trailers being delivered to people with no access to a tow vehicle. I don't want to take advantage of anyone, and would like to figure out a fair price.
vintageracer
To Infinity and Beyond!
Price your truck and put it up for sale.
Quit worrying about losing a Dollar or two cause maybe just maybe you sold it short by pricing it a little to cheap.
Determine your own price that YOU are happy with, post the Burb for sale and you will find out rather quickly IF your price is reasonable or overpriced!
If you have to ask the internet to price your Burb the chances are GREAT that YOU think more a lot more of it than those looking to buy will think of it.
john61ct
tells a lot about engine issues if done before change interval
about $35
______
Has there been corrosion from its past in snow country road salt?
john61ct
Extremely nebulous concept.
The maximum you can get is "fair" to the person actually willing to close on that price and actually fork over the cash.
But you will need to put in a lot of time & energy (maybe $$) marketing it to reach those prospects and get that price.
And if they are rich and stupid, you are of course "taking advantage" of them.
Rwatson8
Well this exact vehicle with 85k miles and in very good shape and nice add on just sold for $15k so I'd say $8-10k maybe
Tex68w
Beach Bum
Retail book in the Houston area for the condition you describe is between $4,000 and $8,200, that's quite a range. If you cleaned it up some and replaced the dash and door panels that are messed up I wouldn't be afraid to ask $10K firm in this current market. I don't know how much you're into it but you could probably fire sale the thing for $6K as it sits easily.
skrypj
A Whippled 8.1L 2500? Does it get negative gas mileage?
I saw a Burb 2500 the other day on 37x13.5's. I was so excited. My wife saw it and face palmed before I even had a chance to say anything :ROFLMAO:
V45W_Proto2.5
