72 IH + ‘85 Alaskan = Questionable Judgment...
Nailhead
A few days after I got back I got a nice surprise:
Black Friday isn’t all, well— black.
Nailhead
A few days later, I decided to test my new solar suitcase.
First, I removed the valve core from my trailer spare and then refilled it with my compressor (the highest-amp load I could come up with):
I did this two or three times. The result:
After maybe an hour on the panel:
I like this thing, and it wasn’t very sunny out.
Nailhead
Next, it was time for a permanent fix for those broken-off corner angle rests.
A few essential components from McMaster:
Removal of the range for access to the DS mounting point (with surprise bonus!):
A little cutting, drilling, and tapping later, and we have rests for the upper camper section:
Nailhead
This is the skid plate/support for the dumpster-find 19-gallon F350 auxiliary tank, which I coated with a POR-15-type product from KBS:
I was incredibly lucky to find this tank, because it fits the space on the rear of the truck, it will allow a usable range, and it was free. It, and its ancillaries, are worth their weight to me.
The end result on the tank support, air tank, spare carrier, and other parts.
Nailhead
And then a really big day arrived:
We got to this point and realized somewhere our height measurements weren’t right, and we needed 3/4” at the top of the boxes and below the cabover. Harry suggested a sheet of green-treat 3/4 plywood as a spacer, noting a couple fringe benefits: 1. Better floor insulation. 2. Increased weather protection for the bottom of the camper. Since such a product isn’t economical to purchase in Wheatland, WY, the mating-up of camper & truck was put on hold for a couple of weeks.
Nailhead
Back at home, I decided to liberate the cabling I wanted to use from battery to inverter/charger from its covering:
This was a castoff from my oilfield days, and it was a PITA to extract that cable, but a couple beers later, I had ‘er licked:
It’s 2/0, IIRC.
Lockwoodjd
