Rail on rail subframe end treatment.
Ramdough
All,
I was looking at rail on rail subframe end treatments and came across a bunch of conflicting information.
Fuso does it this way:
Mack Trucks does it this way:
Australian government calls it out this way:
And my Haynes manual uses 1/3 of the height of the rail tapered for at least the the height of the rail back in length.
So, I am looking at the taper to cut in a rectangular tube and I planned to use the Australian method. My subframe will actually be on top of a subframe that exists on top of my main frame, so I still get quite a bit of load dispersal before the main frame sees anything. Also, I plan on having a HMWPE or similar layer between rails.
Thoughts?
Victorian
I would go with your trucks manufacturer recommendations. At the end it doesn't matter what regulations are in Australia if you are in the USA.
Ramdough
I would if I could…. They don’t have a builders’ guide.
Tell_me_more
Hey what did you end up going with? Would you be able to share some photos of your sub frame? I am just being my build here.
Cheers!
V45W_Proto2.5
