Sold - XVENTURE XV-2 with RTT, 2015 excellent condition
Johnny5!
Selling my 2015 Xventure XV-2 trailer with tons of options in excellent condition! Family has grown and we are looking for a bigger camper.
This is an incredible setup for going off-the-grid and can haul a ton of gear with you. Really a very unique and incredibly well-built trailer!
STANDARD EQUIPMENT
  • All Aluminum Construction using patented huckbolt system - checkout the Xventure website, this thing is a tank!
  • Large Front Storage Cabinet – 62 wide x 22 tall x 19 front to back. All Aluminum.
  • Multi-Axis Max Hitch.
  • Electric Drum Brakes.
  • Dual independent manual Brake Controls.
  • Break-Away brake actuator.
  • Power Distribution Center - Completely wired with 6 fused switchable supply ports.
  • Wiring harness runs through chassis tubes for optimal protection.
  • Cargo bed mounted 12VOLT receptacles.
  • Line-X Coating - Cargo Bed Interior and Front Exterior Wall, Chassis, Fenders, Storage Cabinet
  • Rear 2" accessory receiver.
  • 2: Rear D-Rings and spare tire mount.
  • 10 Year Warranty on Chassis.
ADDITIONAL INCLUDED EQUIPMENT
  • James Baroud Roof Top Tent Grand Raid Evolution - this thing is amazing!
  • Elevating cargo rack (80/20) with gas shock lift assist - allows you to fit more on the trailer like an ATV
  • Oztent Foxwing Awning w/ 3 zip on walls - such a great additional option and creates a semi enclosed area for hanging out and cooking.
  • Goal Zero YETI 400 Power Station + 60Watt Solar panels.
  • Deluxe Lighting Package: 6 Rigid Lighting area lights. 4 Rigid under bed rock lights. 3 Rigid in-bed lights.
  • Galley Table w/ sink & faucets - All Metal, 89" x 18" folding
  • Hard folding tonneau cover.
  • Built in water pump but NO built in water tank, this was a non-Xventure upgrade. High-end RV pump and PEX tubing installed via standard Xventure routing. However, rather than mess around with a built in water tank that needs to be winterized, I set it up to use 5-gallon containers. Works great for sink + shower.
  • Water Heater (Propane) w/ shower.
  • Propane Tank (20 lb).
  • Toyota TRD 16" Rims with KO2 tires
Without the RTT and additional extras, the trailer is over $15k new, http://www.schuttindustries.com/XVENTURE/XV2
Asking $15k - great deal (replacement cost would be ~$25k). You will never find a trailer that is so well built and versatile. Selling because family has grown and we need something bigger. But will be very sad to see it go.
Jeddly-Bo-Deddly
Glad to see my home, great state of NH represented! Great rig. If I had the $$ would buy immediately.
iStan814
