RedArc vs Victron... REAL WORLD USE pros and cons?
john61ct
Voltage has little to do with power.
The 75/15 unit (USD $125?) is designed to output only up to 220W, so up to say 280W panel Pmax rating
john61ct
Please clarify your statement since volts x amps = watts (power).
Just because the SC is designed to handle a panel with high Voc spec on its input
does not **in itself** imply its ability to output lots of amps.
Unless your **system voltage** is increased.
So a Victron capable of charging a 48V bank can output 4x the watts compared to a 12V bank.
Note that system voltage has nothing to do with panel voltage.
Note that to be safe you should derate that Voc max spec by at least 10%, and 20% is much safer. However, going too low, say under 40-45Voc, does not give the MPPT enough headroom for its optimisation algorithm.
But on the output power, better to "overpanel" to get best bang for your buck, 20 to even 30% will give you much higher **average** charge capacity,
the ability to capture 100% of (rare) **peak** panel output is a fool's errand, waste of money.
So assuming optimal 1:1 SC ratio, an ideal panel for that 75/15 model in a 12V system would be 40+Voc and 240-280W theoretical max power rating.
Keep the Voc the same but double the power for a 24V system.
Hope that helps.
RAM5500 CAMPERTHING
OG Portal Member #183
Hope that helps.
Agree 100%, good info
that was my reasoning for the 150/70, gives me safe buffer both ways
Mtpisgah
So if I am running a Victron 100/20 with a 180w panel, am I doing good? 12v system with a Genesis dual battery.
DiploStrat
2x180w panels should be able to produce around 10A in perfect sun, so a controller that can output 20A is fine.
Guessing that those panels run at about 25v, then in series, you are looking at 50v, so a controller that can handle up to 100v is fine.
Mtpisgah
I only have one panel, but sounds like that is ok just slower. It is on an AluCab canopy camper and takes up about 3/4 of the top.
john61ct
The 100/20 is overkill.
If you ever want to expand with portable panels, all identical if multiple panels, use that one to handle 300 + watts.
75/15 will be fine for that fixed panel
DiploStrat
Sorry if I misunderstood. I assumed that you already had a controller and wanted to know if it would work.
If you are designing a new system, you could do worse than to use this calculator. I would feed it the numbers for the biggest system expansion that you can imagine putting on your truck.
MPPT Calculator - Victron Energy
DanoWall
