SOLD: in Tucson, Arizona: 2017 Custom Tear Drop Off Road Trailer
VDBAZFJ
This Trailer is like new, it was built in 2017, has a clear Arizona Title and is currently licensed and kept in my garage in Tucson, Arizona.
It only has 50 miles on the new axle, suspension and tires.
This trailer is built with an all steel frame, to be durable and to go anywhere your off-road vehicle can go. It has all the features to get you off the grid.
Features include:
  • Kitchen with sink (hot and cold water), lots of storage and lighting
  • Camp Partner Stove fits on drop down table on swing out next to kitchen. Propane tank mounted on swing out also.
  • 2 propane tanks
  • Propex Heater
  • Outdoor shower
  • 6 gallon water heater
  • 18 gallon water tank
  • Fantastic Fan with rain sensor
  • Full Extra Long Mattress, 10 inches deep
  • Fox Wing Awning on right side
  • 79" Awning with Annex Screened in Room on left side of trailer
  • 100 Watt Renogy Solar Panel
  • 12 volt battery
  • Timbren 5200 pound axleless suspension
  • Method Wheels with new General Grabber ATX tires
  • Electric Brakes
  • Max Coupler Hitch Included
If you are interested in learning more, there are subsequent posts with additional pictures and build information.
Price: $26,500
Other Trailer manufacturers sell similar trailers for over $40k.
PM me if interested.
Thanks!
VDBAZFJ
Interior:
All birch cabinets built by cabinet maker in Vail Arizona.
9” Full XL (54x80)Mattress that I cut into three pieces and modified the original covering to keep the memory foam top in place. If you have ever made a bed in a tear drop trailer, you know it’s a pain to get the sheets on while you are sitting on the bed trying to pull the corners up. This three piece mattress solves that problem.
Fantastic fan with rain sensor in roof
LEDreading lights.
Smoke and CO detector.
Thermostat to control Propex HS2211 propane heater.
Curtains on both doors and stargazer window
VDBAZFJ
Kitchen:
All birch cabinets.
Stainless sink
12v USB charging ports
Overhead LED lights
Under cabinet LED lights
Lower cabinet has a drawer for utensils, etc.
Two 2.5 gallon propane tanks.
VDBAZFJ
Left Exterior:
CVT 79” awning
ARB annex room. I modified this to attach to the trailer to provide a way in and out of trailer and to prevent bugs from entering when zipped up.
VDBAZFJ
Right exterior:
This side has the same 30x36” door
The water fill door
The shower control and hose door
The large box is the Propex HS2211 heater. This has two exits inside trailer. One is a vent down by where your feet will be. The other is the two small round vents you see in center section of the cabinets. The one propane tank fuels the heater as well as the water heater.
Foxwing 270 degree awning
Porch light
VDBAZFJ
Tongue Box:
1000 watt pure sine inverter
Dual battery charger
Solar controller
Dual battery on/off switch
One battery
Fuse block
Zamp solar input
NoGo shore power input
LED lights on each side to illuminate inside box
XO tongue jack
VDBAZFJ
Frame and Suspension:
I mimicked the Turtleback frame and originally I had used the same Torsion Axle they used to use.
In May of 2020, I redid the suspension by installing the Timbren Axle Less HD suspension. This is the 3500 axle with 5200 components including 12” brakes. There is less than 100 miles on this set up.
The fenders are steel tube with aluminum skin. You can stand on these to reach the roof
I then sprayed the frame, tongue box and fenders with 2-part Raptor Bedliner
VDBAZFJ
Wheels and Tires:
Wheels are 17” Method Race Wheels (the standard)
All three Tires are brand new General Grabber ATx in 285/70/17. Less than 100 miles.
Note: the small white cap you see is the drain for the sink. It is installed correctly now.
Dodgeybassterson
Very impressive build brother! I am interested. GVW ? The hitch is ? not familiar with the look. Is it articulating style?, name?
I like the plywood you used for the cabinets. I've used for cabinets also, good stuff!
Louisd75
Looks to be an older version of CU Offroad's Max Coupler.
@VDBAZFJ did you build the trailer?
VDBAZFJ
Thank you guys for the nice words!
it is a max coupler.
I built the trailer with the exception of the cabinets. I had a cabinet maker build those for me.
Dry weight was 2250 before the heater install. Probably added 50 pounds.
Dodgeybassterson
Thank you. Getting my ducks in a row! lol
PNWav
