J-Spec FG638E
JDMBrian
Recently imported from Japan.
10k miles on chassis
4d35 diesel engine
New supersingles and Toyo 37’s
Custom RV domacile
Rear power lift gate
Box is getting an update and all furnishings have been removed
Kinugawa turbo upgrade in the works
SkiFreak
Crazy Person
Sadly, any links that I might have would be in Australia, which are probably not all that useful to you.
rideglobally
This turbo is a kinugawa kit for the 4d34 i believe, and so far the manifold looks identical to this 4d35. No one seems to have one for the 4.6. Even though thete is a 4d35t engine from mitsubishi.
I did some searching for a turbo set up for this engine before and could not find one that is plug and play. Great platform for a build i will be watching. Thx for sharing.
JDMBrian
I order up parts from australia frequently, but ive already contacted 1/2 a dozen turbo outfiters and it seems the 4d35 never was produced in the Australians market.
SkiFreak
Crazy Person
Does the port size of the kinugawa exhaust manifold match the size of the ports on your engine, or are your engine exhaust ports larger?
Wazak
What year is this truck?
I like the look of it.
Did you import it direct or through a company?
yabanja
Sweet ride!! I would be interested in finding out where you sourced the exhaust manifold/turbo setup? Allan
JDMBrian
Almost finished ironing out the turbo, downpipe, and intake/crossover tubes. Everything has been trial and error of course.
JDMBrian
Kinugawa ebay kit manifold bolted up correctly.
