----SOLD----- 4X4 AMBULANCE CAMPER CONVERSION - 6100 miles / 9816 kms. Price Dropped to $57,500 from $62,500 USD
gaetzjm
2006 Ford E-450 Cutaway Diesel Van with Ambulance Compartment
Vehicle NOS when Purchased January 14, 2019, with documented odometer reading at 28.3 km/17.6 miles
This unit was part of a fleet of ambulances manufactured for the Province of Quebec but never put into service. It was stored in a climate controlled warehouse from 2006 to 2019. Since I purchased it, the vehicle it has been stored in my heated garage when not sparingly used
Licensed as an RV/Motorhome in BC., Canada
Current Mileage: 6100 miles / 9816 kms.
CHASSIS:
Manufactured in the USA
6.0 Liter Powerstroke Diesel Engine, 5R110 Five Speed automatic transmission
Wheelbase 158 inches
GVWR 6372 kg / 14,050 lbs.
Dual alternators (140A + 120A)
Auxiliary rear compartment A/C & Heater package, operates only if engine is running
Factory (Quebec) installed rear compartment insulation package
Power windows, locks, captain chairs; Cruise control, tilting steering wheel etc.
4X4 FRONT COIL SPRING CONVERSION:
Professionally installed by Clydesdale (Sportsman Light Truck Ltd., Kamloops, BC)
Completed June 15, 2019 – Vehicle mileage at 1137 km
Rear Axle: Sterling 10.5” w/ Detroit Truetrac limited slip w/4.10 differential gear ratio
Front Axle: Dana Super 60, open differential w/4.10 gear ratio
Ford F-350 NV271F manual shift transfer case.
Wheels: 8x200 mm steel dually wheels w/ five 255/80R17 Cooper ST Max tires.
Tracks straight and true on the highway, no wandering, no bump steer, no D-wobble etc.
CAMPER CONVERSION AND UPGRADES:
Engel MT45F-U1CD-P Fridge & Freezer Combi, 12vdc & 120vac
EccoTemp L10 2.6 gpm propane tankless water heater for outside shower & plumbed to the inside sink system
Samlex EVO-2212 (12v 2200w) Inverter/Charger w/ EVO-RC remote control
1080p digital 7” display w/look-down wireless reversing rear camera
Atoto A6PRO 7” Android stereo head unit with wired rear view camera, also configured to display relevant Diesel PID’s using TorquePro/Bluetooth ODBII Transmitter
Blue Sea 7622 ML-Series 12v, 500 amp ACR (automatic charging relay)
Two GC CR235ah 6v Lead Acid Golf Cart House Batteries in series.
Espar-Eberspacher D4 Diesel Heater, Digi-Max thermostat controller
Toshiba 5000 BTU 120vac rear compartment air conditioner, vented to the outside
Fan-Tastic Fan model #2250
Fiamma Awning F45S 300 cm length
Maple Cabinetry and Paneling throughout
Auto Meter 8444 Pyrometer / EGR gauge Kit
SCT X4(7015) Ford Tuner w/ Custom 40 hp Tow Tune
Stock ford EGR cooler replaced with a bullet-proofed one. Replaced the failure prone STC (snap-to-connect) fuel line fitting with updated solid version
Curb Weight: 5210 kg / 11,486 lbs w/ driver onboard, half tank of fuel, water tanks empty.
Full Service and Multi-Point Inspection performed on Sept. 3, 2021 by Knighthill Automotive, a major Service Center used by the Provincial BC Ambulance Corporation
Excellent, Like New Condition. Everything works.
Here are a couple of previous threads from this forum relating to these vehicles
Abitibi
Bump for an awesome ambo! A bit surprised you're already selling it, to me that would be a keeper!!!
Did you mentioned where it's located, BC?
Good luck!
David
Sent from my SM-G973W using Tapatalk
gaetzjm
Hey David, appreciate the bump. The vehicle is located in White Rock ( Vancouver BC Suburb). We met about 3+ years ago when you kindly visited here to show me your Ambo, as I had contacted you with some questions. That's how I contracted the Ambo bug.(y)(y) As you see from the mileage my wife and I don't use the vehicle much, so time to free up some garage space. Nice job on your new one too.
A few more pics?
Cheers,
Jim
gaetzjm
$5000 PRICE DROP
The price for the Vehicle is now $57,500 USD.
Also, here are some pics of a Couch/Slider Slat Bed I am just finishing up building. I have the vehicle stored away in my garage for the winter, so a perfect time to do some projects on it.
20211116_131018.jpg20211116_131231.jpg20211116_131447.jpg20211116_131827B.jpg20211116_132952.jpg20211116_133534.jpg20211116_131545.jpg20211116_133709.jpg
baggio95
GLWS. Real nice job with the bed! I've been trying to figure out what to do with mine and I really like that design.
crostopher
