6x6 M1087 FMTV Expedition Rig
M1087FMTV
Listed $468,000.00 Currently, the ONLY M1087 converted to an overlanding rig & tiny house on wheels. This unique and rare command center offers an incredible tiny house size of 15 x 14 when both sides are expanded. Off-road capabilities paired with luxury interiors, far sturdier than any RV on the market. Built for extreme off-road, no flimsy plastics or light weight wood here, all steel and aluminum construction.
Tour the rig: Link to tour video * If link doesn't take you there, find here: @M1087FMTV on YouTube
For more Pics and Specs: For Sale Page
All Social Media Links for more pics of the rig and the adventures it's been on so far
Specifications
  • 120v AC / 24v DC / 12v DC power systems
  • Victron
  • Multi Plus 24 / 3000 / 70-50 -120v inverter / charger
  • MPPT 150 / 60 - MC4 solar charge controller
  • Color control GX
  • BMV-702 Battery Monitor
  • Battery Protect 12/24V-100A
  • Felicity Solar LiFePO4
  • 3.75 KWH @24V
  • 3 battery packs (600 amp/hrs)
  • 5 solar panels Q.PLUS L-G4.2 Solar Panel 340 Watt, 72 Q Cells
  • 1700 watts
  • On rail system so half the roof can be used
  • Siemens TPS-C1/120
  • Surge suppression device
  • Lamboda LZS-1000-3
  • 115/230vac to 24v power converter
  • Bussmann 24 to 12 power converter
  • USB power outlets
  • 12v power points
  • On demand tankless propane hot water GSWH-1
  • 24V Espar D10 hydronic heater
  • 12v hot water circulation pump
  • 12v fresh water pump
  • Water
  • Isotherm 20 gallon marine shore and coolant hot water tank
  • 60 gallon fresh water tank
  • 80 gallon total
  • 35 gallon grey water tank
  • Dometic cassette toilet
  • LG mini split LSU120HXV
  • Smatplug shore power connector and cable
  • TRUE INDUCTION DOUBLE BURNER TI-2B COUNTER INSET INDUCTION COOKTOP
  • 55 inch TV. Sony X750H 55-inch 4K Ultra HD LED TV -2020 Model
  • Pacbrake
  • Vitrifrigo DRW180AIXD4-DF dual drawer refrigerator / freezer
  • Military heater, water and ration
  • Spring RCC7AK-UV Deluxe Under Sink water purification system
  • Dual filtered faucets
  • Delta 54445-SS-PK H2Okinetic 5-Setting Shower Mount Handshower, Stainless
  • Delta T14001-SST2O-LHP Angular Modern Temp2O
  • T&S commercial faucet and sprayer
  • Cat 3116
    • 33,000 miles
  • Allison 7 speed automatic MD3070PT
  • Led lighting
  • 120 volt led lights
  • 24 volt led lights
  • 12 volt led lights with color changing DMX controller
  • CD/ stereo with back up camera
  • CB
  • All new truck breakers and relays
  • CTIS tire inflation system
  • 1997 Stewart & Stevenson M1085 long wheel base truck
  • 2007 AAR expansible shelter
  • Hydronic engine block heater / hot water heater / forced air habitat heating
  • King size memory foam bed
  • Level the bed instead of the truck
  • New bearings on slide out mechanisms
  • New CTIS and wheel bearing seals
  • 55 gallon fuel tank
  • Led headlights with color changing halo
  • Insulated cab
  • Weboost
  • Optimizer marine wifi range extender by Red Port
  • New parking break controls
  • 8 gallon propane tank
  • All stainless steel shower, sink, refrigerator, kitchen
  • Military black out window shades
  • Military black out system
    • Switches all interior white lights off and turns on blue lights if any door or window is opened
lucilius
This is quite an interesting vehicle: congrats on a very cool creation. I am looking at your pictures and wondering what are the tie-down straps holding below the TV in 7.jpg?
How is the noise level at highway speeds?
M1087FMTV
Thank you! The straps behind the TV are redundant safety straps for the battery bank.
The noise level at highway speeds is acceptable. We installed Dynamat, foam and carpet, prior to that it was loud as hell. We listen to books, music and talk to each other without headphones while on the road, so we find it acceptable.
High Water
Baja Bliss
I have been in this beautifully built truck and the amount of spaciosness and well thoughout layout is amazing. Of course, the wonderful owners make it extra special. GLWTS and to the next owners, you will not be disappointed.
seth.c96
