Hi KeithWells, thank you for clarifying that for me and I can see whey it would be a weak point. Do you a some pictures of how you did yours? If you don't can you please take some pictures of it so I can see it. Thank You.The part that will break is the factory angled bracket. Have them weld a boxed gusset under that corner. The welds are all but ground away there.
Yes, he already had the metal spacer with him on the day of the install so he already has the right height figure out for the install. I had then powder coated. I had everything regarding the bumper powder coated for $160.00 here in Corona, CA I think that is a pretty good price if you look around you can find a good deal on powder coating (I think).There both pretty good tents. I think the 23zero has a bit of a thicker material so it may hold heat better. Also thank you for the photo's of the bumper installed. Did he have to add those metal spacers so the door would open?
Rob modified mine so it doesn’t need a spacer. The install was very easy, he drilled the holes and I mounted it after I painted it, but drilling the holes was really easy.Yes, he already had the metal spacer with him on the day of the install so he already has the right height figure out for the install.
