Ujoint Offroad Colorado van build thread!
UjointoffroadCO
Approved Vendor
Have this '75 volvo c304 in the shop getting rehabbed after a long sit full of fluids. Have a bunch of parts enroute from sweden for it!
Since my van is rendered unless as a van, I have to use the daily as a work truck!
Had this bad boy in the shop Getting cleaned up and pics taken to be listed for sale. Hefty price tag, but still cheaper than if you had to build it yourself. Done at the mothership in NC last year.
Sunsets are nice at the new shop
Breaking ground on the cream puff finally. Should be seeing springs any day now!
Took a 3 day to do the gateway to casleton route into moab. Highly recommend if you are headed from southern CO into Moab.
This is a bit of whiterim in canyonlands.
Finally have all the parts to do a Cool build on this retired airforce EB. Getting a 2wd action vans lift, 33s, OX locker and chromoly rear shafts, and a sweet brake upgrade.
UjointoffroadCO
Approved Vendor
Finally got everything wrapped up on the action vans 2wd lift kit!
Had a take off set of Atlas rear leafs laying around that were a perfect spec for this van, so I threw them in instead of using the block that comes with the kit. We also did a OX locker and 35 spline chromoly shafts. Got a full power brake upgrade also.
Also installed a transit 3 place bench seat for the customer.
Came out pretty cool! The high top I installed didn't work out, so it went over to utah for a tough port high top instead
Love a good before and after
With that wrapped up, I was able to set aside a little time to get my new Ujoint rear bumper on! Working on some little projects for using the inside of the pelican box better.
The Rigid reverse lights are crazy bright!
Alright, back to the b190! Leaf springs STILL aren't here for this thing, so I've just been doing what I can until they show up. Frame cleaned and painted.e
Stage 1 front axle built
Full rebuild on the rear full float 60 with a ox locker and chromoly shafts.
Expecting springs any day now. Should be on the ground soon!
Bobfab
All looks great! How did you install the transit seats? Any reinforcement on the bottom? I have them installed in my van and was curious!
Sent from my Pixel 3a XL using Tapatalk
snowgroomer
Interested in your pelican box upgrades
UjointoffroadCO
Approved Vendor
Is it the angle of the picture, or are the tire and bumper showing a display of affection to each other?
They are very much touching. Good visual of how far forward our kit pushes the front axle! I had to just get the wheels on it to measure for driveshafts. We cut the bumpers to clear before it leaves.
UjointoffroadCO
Approved Vendor
Been a while since an update! The b190 has turned into an absolute nightmare. Has a seemingly un-fixable driveline vibration. Transmission has been gone through twice, 2 different transfer cases, driveshaft rebuilt and rebalanced 3 times, rear diff rebuilt at least 10 times, 3 different ring and pinions, new rear hubs, new pinion flange so on and so forth. Going to try a totally new driveshaft this week and hope thats it.
Flex check
Flush mount paddle valves and dual needle gauge for the rear bags
All shapes and sizes
Annual Christmas tree photo
One of my favorites back in the shop getting a front bumper, lights, winch, Spod, OBA and bushwacker's
Next project has arrived!
Pallet ready to go!
Happy new year!
xleratin
Hey, It's been a while since Ive read you're entire thread, and I apologize if you've gone through is already, but what kind of fuel mileage are you seeing with you 5.4 and the lift/tires?
UjointoffroadCO
Approved Vendor
I honestly don't keep track. It's best not to know. If i had to venture a guess, it's between 8-10
motovan_mn
That seems to be the general sentiment :LOL: But I'm the kind of guy that likes DATA so I will certainly be recording mine, despite how much pain it will cause me. There's a few good data points on the SMB forum as well.
UjointoffroadCO
Approved Vendor
Big update!
You'll be glad to know that the b190 is fixed! New driveshafts from a new shop fixed the vibration. Delivered back to a very anxious customer! Here's some final pics
Pretty proud of my OBA solution. Not a lot of room under these things!
Took sometime to build a little leaf spring rack to try and better use my storage space.
Next van in and torn down in short order!
Took a long weekend to go see some friends down south
Back in the shop! Parts starting to stack up!
Hired a good buddy to come work with me part time. Production is through the roof!
Touch down! Measuring for shafts!
Sub floor storage going in.Such good use of wasted space. Wish I had room in mine for it!
Fully loaded bumpers showed up!
Looking sharp!
Thats it for now! More soon!
DFWSFO
