**Sold** Custom 2019 Ford F450 & Removable Autarky Camper. New Price ($195,000)
dcrzach
Hello again Expedition portal -
Zach Reinitz back again with my latest camper build.
Our latest build is a truly awesome machine. It is an international, overland-ready expedition vehicle built with the highest regarded industry components. The truck manages rough terrain smoothly and provides a luxury driving experience on the road. The camper utilizes Timberline’s diesel-powered hydronic heating system along with a Wallas diesel cooktop. This means you never have to stop for propane again. The entire camper runs off a single fuel source - whenever you fuel up at a diesel station you’re also able to ensure your cooking and heating sources are topped of as well. The camper features a drop out shower stall and slide out toilet – providing the benefit of a fully enclosed bathroom but utilizing far less space in the camper. The lithium powered solar system keeps everything powered up virtually indefinitely, leaving you ready to explore without planning to conserve power. The 6.7 Power Stroke engine moves the truck along swiftly with more than ample torque for even the steepest of mountain grades. Rough and rocky terrain? Deep desert sand dunes? Deep water crossings? Don’t worry…with 42” Continental tires on bead lock wheels you can simply air down, engage your front locker, and continue to push though the most challenging terrain on route to your next dream overland destination. Once your back at camp, easily air up utilizing the onboard air system plumbed to each corner of the truck. Nighttime falling? Kick on your exterior rigid lights, crank on the interior floor heat and settle into another awesome night on the road. Once your back at home after a long adventure, you are free to simply lift the camper off the truck, using the Rico lift jacks, leaving you with an off-road ready, flatbed work truck/tow machine.
Instagram Handle - AutarkyEV
Price Reduced - 215,000$ - Contact Zach at 775-200-3591
The Truck: 2019 Ford F450 Ultimate Lariat - 51k miles with Brand new Autarky Camper Buildout.
Factory Features:
  • 6.7 liter Power Stroke Diesel with 6 speed Auto trans 4WD
  • Lariat Ultimate Package - Navigation, Remove Start, 10-way Driver/Pass Heated/Cooled Front Seats
  • Tow Technology Bundle - Adaptive Steering, Lane Keeping Alert, Ultimate Trailer Tow Camera
  • FX4 Off-Road Package
  • Extended Chrome Running Boards
  • Power Moonroof Twin Panel
  • Quad Beam LED Headlamps
  • Fordpass Connect 4G WiFi Hotspot
  • Remote Keyless Entry
  • Powerscope Power Fold Heated Mirrors
  • Roof Clearance Lights
  • 360-degree Camera System (includes 7 cameras)
  • Sirius XM
  • Sync 3 with 8” touchscreen
  • Trailer brake controller
  • Hill Decent Control
  • Auto Dual Zone Climate Control
  • Upfitter Switches
  • Dual Extra Duty Alternators
  • Universal Garage Door Opener - 3 way
  • B&O Premium Audio
Truck Custom Build Features:
  • 41” CONTINENTAL MPT81 TIRES
  • Super Single Conversion by DBL with custom 20” beadlock wheels
  • Custom Front Tire Flares coated with Bedliner
  • Custom gearing installed by DBL
  • Bedliner on rocker panel
  • 2-1/2” lift kit
  • Custom Fox 2.0 Shocks tuned for this application
  • CM Aluminum Flatbed with 4 storage boxes and Mac’s tie down track
  • Custom fenders for rear tires
  • Electric Front Differential Locker
  • Road Armor Stealth Lonestar front bumper
  • Smittybuilt 17.5k winch
  • Rigid 40” E-Series LED light bar (relayed to high beam)
  • Rigid D2 LED lights with amber covers
  • Rigid DOT LED lights
  • Rigid Diffusion LED lights in rear bumper (relayed to back-up lights and switch in cab)
  • Extreme Outback Magnum 12v compressor with 5-gallon air tank (switch in cab, outlets in both rear boxes and front bumper & gauge)
  • Rear suspension air bags with separate compressor and wireless remote
  • Centramatic auto wheel balancers
  • Mac’s Custom Tie Down Track
  • Full width safe under back seat
  • Full size rear swing out Spare tire / camper deck landing/ entry steps. (swings down to clear camper for easy removal)
  • All interior upfitter switches utilized for accessories
The Camper:
  • Full aluminum welded frame construction (frame core photo attached)
  • Riveted and Sikaflex adhesive exterior aluminum skin panels.
  • 2in of closed cell foam insulation on all walls and roof
  • Insulated aluminum subfloor with underfloor hydronic heating
  • Rico Titan Electric Automatic camper lift system with remote control
  • Custom CAD designed rear spare tire carrier/ entry steps and landing.
  • Marine Vinyl insulated woven flooring
  • Marathon Tweed Grey Heather insulated/cushioned interior wall panels
  • All Custom lightweight Birch and Bamboo cabinetry
  • Indel B Marine 12v fridge/freezer
  • Wallas Diesel Cooktop
  • Push/Twist latching storage compartments with Froli Cabinet organization system
  • Stainless Terra Van Custom Shower Stall with Skandvik Faucet
  • 1000lb drawer slide Toilet stall with Thetford Cassette Curve toilet
  • Dinette Seating with flip up bamboo table
  • Fixed over cab King size bed with 4in luxury memory foam mattress
  • Custom made matching marathon tweed Dinette cushions -converts to additional sleeping area for 1
  • Complete soft white Redarc controlled lighting system with RGBW under cabinet mood lighting flushed into aluminum trim accents – with touchscreen controller
  • Max Fan- Rain sensor and remote control
  • Various Interior 120v GFI Dual outlets along with 12v USB charging ports
Power System –
  • 400W Rec N Peak Rooftop Solar array
  • RedArc TVMS Bluetooth Charge controller
  • RedArc BMS with Shunt – Interior controller
  • 1500w Compact Cotek Inverter
  • 200 Amp DC disconnect
  • 30 Amp 120v interior accessible breaker panel containing all circuits both AC and DC in one easy to access and maintain panel.
  • 100ah Expion360 Lithium Battery bank
  • Anderson quick disconnect to truck – Charges house batteries while driving via red arc TVMS system.
  • Exterior 120v weatherproof power ports
Water, Heat ,Cooling –
  • 35 Gallon Fresh water tank – SS marine inlets
  • 15 Gallon Grey water tank
  • Pentair 12v Water pump controlled with RedArc Main panel
  • Timberline Hydronic System. Provides instant hot water/ Heated flooring/ Thermostat controlled air exchanger heater. All Diesel powered via external rear mounted fuel tank.
  • All plumbing and tanks are mounted within the insulated interior and will not freeze while camper is heated
  • Maxfan Deluxe
  • 12v Sirocco 2 Cabin fan in bed area
Dimensions/Weight –
  • 24ft overall length bumper to bumper
  • 11ft total height
  • 6ft interior height
  • Truck with camper unloaded 9,400lbs - Ready for Gooseneck Towing
  • Fully loaded weight - 13,260lbs - With a 21k Max Towing capacity
dcrzach
DirtWhiskey
Western Dirt Rat
Rad setup. Any alignment system or just eyeball it and back it up? Looks like those flares would be really close to the jacks. How does it tie down? GLWTS
dcrzach
The Rico titan jacks swing out on hinged mounts to allow the clearance for the fender flares. Alignment is easier than it looks - using the array of fancy backup cameras and the trucks excellent side mirrors -. you simply align yourself using the jacks and flares as your reference point. The campers frame and core supports of the flatbed sort of slot together making for a self aligning system once you begin to lower the camper. Any additional adjustments can be made utilizing the rico jacks to shimmy the camper around if necessary. Its takes me about 15 mins to unload / and I would guess 25 mins to reload. The camper is secured using 4 very large (32mm socket) grade 8 bolts that secure through the flatbed and into a reinforced frame section of the camper. The spare tire swingout has one bolt removed from the upper heim joint and the entire unit will swing low enough to clear the camper. The process becomes very simple after a little instruction and practice .
flafonta
Great Overlander!
Question on your flatbed. Is this a standard skirted CM flatbed or did you have to custom order or modify to fit the 41" supersingle?
