SOLD: Price Drop- Fully Loaded XV2 Trailer $16,999
etherbunny
SALE PENDING 2016 XVENTURE XV-2 off-road trailer from Schutt Industries
Price:
$16,999
Mileage: Approx 9,000 miles; Mostly paved and forest service roads.
Great set up allows you to set up camp, then disconnect and go explore.
Description and Specifications:
  • Length: 156” (incl. tongue)
  • Width: 79” fender-to-fender (75” track)
  • Cargo bed interior:
    • 59”W (49” between wheel wells)
    • 89”L (minus 6” for folding galley table)
    • 19”H to bottom of closed tonneau cover
    • Up to 56”H from bed floor to bottom of rack when elevated and tonneau cover folded/removed
  • Ground clearance: 14.25”
  • Suspension: 3,500-lb. Dexter independent rubber torsion axle
  • GVWR: 3,500 lbs. (dry weight in current configuration probably in 1,300–1,500-lb. range)
  • Tires: 35" BFGoodrich T/A KO2 tires
  • Wheels: AEV 17" Borah 5-lug wheels that fit Jeep JK and JL hubs
  • Hitch: Lock and Roll hitch, including car side with standard 2" hitch
  • 7-pin connection
  • Electric brakes and emergency breakaway system
  • Independent mechanical parking brakes
  • Rear 2” hitch receiver
  • Two recovery points at rear
  • D-rings at each corner allow the trailer to be airlifted in a pinch
Features and Accessories:
Base Trailer plus Schutt’s fully loaded “Deluxe Plus” package. (new $34,500. Not including tent and other items listed below)
  • Tent
    • Dealer-installed James Baroud Grand Raid XXL hard shell tent (new $5952) in black
    • Tent has been professionally coated with ceramic coat to prolong fiberglass life
    • Tent is in excellent condition. Have put less than a dozen nights in this new tent since upgrading from my previous JB tent
    • Includes Isothermic winter liner kit (never used; new $565), spare mattress (new $300)
    • JB Comfort Pad XXL (new $405)
    • JB Universal Tablet Holder (new $65)
    • Size (open): 63.75”W x 89”L x 40”H
    • Size (closed): 63.75”W x 89”L x 13.2”H
    • Comfortably sleeps two adults and a child or dog
    • Non-smoker
    • Sliding ladder, plus one spare ladder
  • Galley / Cooking / Water
    • ARB fridge/freezer with tie-down kit and optional insulating cover (50Q; DC/AC compatible)
    • ARB wireless fridge monitor
    • Upgraded galley table with diamond plate, mounts on driver side, with cutout for sink. Upgraded under-rack mounting bracket makes setting-up and breaking-down the galley a breeze
    • Galley hot/cold faucet (included) mounts on fender
    • Brackets for three 10# propane tanks with two tanks included. Custom bracket right by galley for easy stove hookup.
    • Propane system plumbed through body/frame
    • Water heater with factory-optional shield with rhino liner coating **see note at end of listing**
    • 22-gallon potable water tank; system plumbed through body/frame
    • Hand-held shower connection on passenger side near RTT ladder
  • Electrical
    • Dual Odyssey batteries with custom battery rack
    • NOCO Genius Gen 2 20A on-board dual battery charger
    • Overland Solar SAE port with solar charge controller
    • Zamp Power 1000W Pure Sine Inverter
    • 12-volt sockets in battery compartment, fridge, and near tailgate
    • 360 deg area Lighting system: lights on all 4 sides of trailer, plus underside ground and bed lighting
    • Additional towing 4-pin hookup at rear
  • General
    • Rhino Rack Pioneer Platform elevating rack system (grants additional 6” clearance)
    • Gas strut-assisted elevation
    • Hard rolling & locking tonneau cover
    • Line-X liner on tongue box, fenders, bed
    • Custom wrap in graphite with topographical lines
  • Other Included Accessories
    • Trailer Jack with a spare handle
    • Manuals
    • Hi-lift and jerry can brackets mounted to passenger side
Repairs / Maintenance:
  • Dealer-installed rear support brackets to add stability to the frame. This is an item that now comes stock on new versions.
  • Annual winterization of the water tank to ensure cleanliness
Known Issues / Notes:
  • Used to have an EZ-Awn 270 deg foxwing awning installed, but I have since moved it to my vehicle. Tent configuration on the rack remains unchanged, so it would be very easy to reinstall an awning of your choice.
  • The water heater is having trouble igniting. New batteries did not help. Not sure if it is the ignitor or if the unit needs to be replaced. They are approx $180 new, so I will knock $250 off the price to cover purchase and install of a new heater.
  • This company started out as a military contract for super-tough trailers. This thing is built very well!
etherbunny
seth.c96
