DIY Camper Build "Ambition 2"
Platinum Paw
Soon, (Over the next couple months) I will be building a Slide in Camper. I'm going to call it "Ambition 2". All of the dimensions will be based on a 2022 Toyota Tundra 1794 Edition.
Here are some preliminary drawings. 8 Foot bed and 2-foot overhang. More or less
Offset door to make space for a bathroom on the passenger side
Bed up front but not on the overhang. Fridge then Bathroom
Driver side has a sink, stove, counter the and the bed. The overhang is for looks and storage but not sleeping.
Wheel wells will be filled in in the back to provide more room. Even though it will be more difficult.
billiebob
for a light, compact camper this is pretty much flawless
Platinum Paw
Thanks! That’s what I need to hear at this stage to keep the motivation going. I had a mishap with measuring the epoxy for my model so I have to start over again. I did not realize that the different speed hardeners also mixed at different ratios.
Platinum Paw
just add an outside door. Excellent spot to store fishing rods or paddles or....
That’s a good idea. I might do that. I’ll work on an idea. I was considering the over cab section having side access up at the very front. It would provide 8 feet of storage and although a tad difficult to access be very useful.
ITTOG
So what are your plans for the overcab section? I feel like you are missing a great opportunity and space improvement by not making it into your bed?
Platinum Paw
I completely agree with you. I'm a little torn on this. Here are my thoughts. Any opinions are appreciated.
1. The over-cab section strength is unknown. Since I will not have any frame, I'm guessing a long overhang may pose a problem at the seams, especially with people sleeping there.
2. If I sleep in the over-cab section, it needs to be taller. I would like to keep the height down as much as possible. Not using it for sleeping gives me a 12-18 inch shorter unit overall.
3. I always need storage, and over the cab gives me a lot of internal and maybe some external if I partition it.
ITTOG
Your reasoning seems sound. You can address any of those items in other ways but you seem to have more reasons not to change.
opp1
fiberglass structural panels that's what you're building from so there's quite a bit to look on the web to see Remember the more you can do flat on the table the easer going to be
V45W_Proto2.5
