2020 Ram 5500 DIY Composite Panel Camper Build Thread
RAM5500 CAMPERTHING
OG Portal Member #183
That's HPI quality right there. Nailed it! (y)
Ha!
Yeah.. super stoked and admittedly a tad surprised how well it all meshes.
I changed my ideas and dimensions on these more than you did with tires. True story. ?
Mounting this side (passenger) will be easy.
The other side will require some shenanigans and in house redneckery to deal with the fuel filler hose.
I’m planning on fabbing up more of these tabs and using 5/16 rivnuts and grade 8 hardware to make for simple removal for service and field repair
This will be in addition to the 3 huge tabs I already have designed into the subframe.
(yes, rivnut is backwards in pic)
StenchRV
Quick test fit today after work…
Soooo freaking happy with how this comes together!!!
It almost seems like I know what I’m doing and planned this…. ?
Sorry for the crappy phone pics
WOW! BEAUTIFUL!!
You know imitation is the greatest form of flattery! Your planning paid off....TWICE!!
Those are going to be a SWEET addition to our 84 CA!
WELL DONE SIR!
CHEERS,
Craig
chris_the_wrench
Fixer & Builder of Things
Like you said @RAM5500 CAMPERTHING the 3500 floor mats fit perfectly. These are the regular cab mats in the front of our crew cab 5500, incase anyone else was wondering... I didn't need a mat for the rear. My HDPE should be arriving today and then hopefully I can start on my bed this week.
RAM5500 CAMPERTHING
Ok, progress finally!
Got the 2 under boxes mounted thanks to the help of some friends, Mike, Mike, and Andy.
I used some large heavy duty 5/16" rivnuts/nutserts and made some tabs so everything was clean, but also so the boxes are easily removable, with one person for truck repair or service.
I had to notch the drivers side one to accommodate the fuel filler neck (heads up here @StenchRV ). I knew this ahead of time, and contemplated having HPI do it from the get go, but for proper fitment, we will be doing it in house and making an aluminum piece to fill this void and seal the box back up.
I am now going to remove the boxes and tire carrier (still needs powder coat) and paint the subframe area where they are mounted and where we just welded the tabs with POR15 before putting it all back together.
Super super happy with how these came out and fit!!!
https://highwayproducts.com/ absolutely nailed it and i am a customer for life!
wfv56
Not a lot of drop from your fuel fill to the tank. Can you pump fuel at a reasonable rate without backup to the fill port?
RAM5500 CAMPERTHING
Yes and Yes
I’ve only had issues at one pump ever.
All others pump at full speed
This was well tested beforehand as I learned this the hard way with my last build. It was a nightmare filling the truck (gas)
But…. “Gas” pumps and GAS filled necks are much more sensitive to the rate of flow versus the Diesel pumps. So there’s that.
4xCoffee
