Solar Power FAQ
Corey
OverCamping Specialist
I like the one for the FJ Cruiser, but the site says for 2010 and on up.
Mine is a 2007, not sure why it would not work.
I take it they are lit up all the time too when the key is off?
Probably no worries though with a low current draw, much like an alarm warning light that blinks all the time.
Corey
Thanks Sky, I think I would go for this option with the simple switch on the ground side.
Seriously thinking of getting this.
Corey
I talked with a guy there, and he joined the forum after seeing the thread.
I still need to order the battery monitor.
Corey
If anyone is interested, the Toyota blank switch dual battery meter total came to $64.50 AUD, but in US currency I paid $49.70, just placed my order.
I think the exchange rate said it was $1.00 US to $1.29 AUD.
Will probably take around two weeks to get it, and after I install it I will have it in my build thread and post a link here to it.
Since this draws such a low voltage, I may just wire them direct.
You do have to add more wire to it, I forget the gauge in my email exchange with them last week, but it is in my email at home.
Question, I have a Blue Sea box in my passenger footwell that goes directly to my aux. battery.
Can I just run the hot lead from this gauges aux, battery side directly to my Blue Sea box since it goes to the battery, or should I run the wire and fuse directly the aux. battery instead?
Corey
Cool, thanks.
It would be just as easy to run it out the same hole that the wire comes in for the Blue Sea box as the battery is right behind the firewall.
dwh
Tail-End Charlie
I thought this sticky thread was supposed to be Solar Power FAQ.
You guys need to start a new thread.
Ozarker
Now I find out after posting!
Mounting section; neither link worked, says page not found.
gp01
