2016 F550 Custom Overlander - San Jose, CA - PRICE REDUCED $215,000
lazybummm
I've been drooling over this unit for quite sometime now...it's beautiful. Have you explored whether a passthrough can be added from cab to camper? How removable is the camper?
oliklink
The camper is removable. As far as a passthrough it would not be practical, just looking at the layout and where the equipment is located.
The truck cabin is well designed with an extra fridge (CFX 85), with a molded platform on the back seat that is perfect to store stuff, for pets, and to create extra sleeping space.
By not having a passthrough, the valuables in the camper are super safe. So many advantages to the design.
oliklink
What is the gross vehicle weight?
Weight & Dimension
• 17,340 lbs (fully loaded – 90 gallons water, 72 gallons gas) - Front axel: 5,760 lbs - Rear axel: 11,580 lbs
• Length: 24 feet (with bike platform: 25.6 feet)
• Width: 7.95 feet (with mirrors out: 8.6 feet)
• Height: 9.7 feet/12.7 feet (Camper Up)
• Wheel base: 14.75 feet (between axles)
(Pictures give you some idea on the modification of the suspensions, etc. - King shocks,
Suspension
• Custom set of Deaver rear leaf springs
• Rear firestone airbags
• Carli front coil springs
• Hydraulic bump stops on front suspension
• PMF fab steering stabilizer
• Custom valved and tuned (by King) 3” rear remote reservoir shocks, 2.5” front remote reservoir shocks
• Custom made front fender flares & Front bumper (Buckstop, Boss model)
• Full bead lock super single 20x11 wheels
• GoodYear G275 MSA (335/80R20) - 41" tires with spare
oliklink
I think the question was, what is the GVWR, not how much it currently weighs.
Sorry, this is the answer from google! GVWR: The F-550 is available with four payload packages, offering Gross Vehicle Weight Ratings of 17,500 pounds, 18,000 pounds, 19,000 pounds, and 19,500 pounds in turn.
I added all the modifications (with pictures) that were done to the chassis, suspension, etc ... so you get a better sense that the unit was designed to be below the GVWR.
oliklink
Going to be traveling to Reno on May 22-23, if someone is interested in viewing the unit along the way. Let me know.
oliklink
Unit is still available and i can show it again as I am back from a 2 months European trip (This unit would have been wonderful in Northern Europe - Norway, Sweden, Finland!)
oliklink
Not anymore. It was removed as the A/C was too strong (Mitsubishi unit 18,000 BTU). There is a great airflow with two fans and the open front (accordion).
Still have 4 Lithium batteries to run an A/C unit.
The space is still available to install a traditional A/C unit. Or, would recommend a portable unit. Here are a few examples:
- https://store.bigassfans.com/en_us/cool-space-200
- https://www.bougerv.com/products/28...MI9NaW1qrI-QIVmB6tBh1PHAJiEAQYAiABEgJa-PD_BwE
- https://us.ecoflow.com/products/wav...MI9NaW1qrI-QIVmB6tBh1PHAJiEAQYAyABEgK_zvD_BwE
- https://www.kapsulair.com
Hope this helps ... Oliver.
DreamWeaver
ok thanks. Noticed no upper storage. How is storage. Under searing, out side, in truck?
oliklink
Actually you have lots of storage-
Inside: Under seats, Special shoe compartment (pull out), two laundry baskets, kitchen drawers (4x), trash can (under sink), Under the bed (front and back. Storage accessed thru lifters) - Also bed can turn into a coach,
Outside: Subframe (can store kayak, skis), storage cabinets (3x), storage in the outside sink, drawers (above outside sink)
Back of truck: Platform to store bikes, eBikes
Back of truck top: Slots to store surfboards, skis, longer items, ...
Inside the truck cabin: back seat has a molded flat bench
Check pictures: https://www.oliverklinkphotography.com/OffGridLuxuryCamper/
Hope this helps ...
mk216v
Der Chef der Fahrzeuge
Too strong? No way to have it on "setting 1" and not frost yourself?
Petersmithinak
