12v Air conditioning vs mini Split
Have any of you guys used a unit like this?
NEKOPKKA Universal 12V RVs AC
https://a.co/d/jjyZ6cx
My Fg has no AC sadly but I only have a 12’ by 6’ camper box so was thinking I could kill two birds with one stone.
Duct a couple of ducts into the cab and leave the rest in the camper.
The other option would be to run a small mini split off the inverter but I fear that the 20% inversion loss would make it less feasible?
What do you guys think?
also looking to upgrade my alternator cause it’s the old 80amp any ideas?
SkiFreak
Crazy Person
The power consumption with that unit is quite high. It would be really nice if you could get an inverter version of an AC of this size, but they don't seem to exist. Sigh........
You need to get a better inverter...
A good one should have an efficiency over 90%.
I have a Victron inverter it’s 92% or 94% I just thought in general there is a 20% loss
Peter_n_Margaret
It is likely that a small Mitsubishi Heavy Industries split will use less power than a 12V unit at full power. They are also powered by inverter motors so efficiency at low power settings will be much better than 12V units.
They will also be cheaper.
They are the unit of choice in Oz to run from batteries and solar.
Cheers,
Peter
OKA196 motorhome
SkiFreak
Crazy Person
Most of the marine units utilize sea water as part of the cooling cycle, which is not really appropriate for land based setups.
Ferjablito
Blismobill that according to what I understand is the best they use this system, the truth is that I have investigated without finding the exact model.
elvan
I have a "Cruise n' comfort" 12v in my npr build. It's great but pricey. I'm using 5-600 watts on full, but does a pretty solid job of keeping me cool. My only wish was it was a heat pump so I had heat from it too, as a back up.
Ferjablito
Hi SkiFeak,
I've been researching the topic of hot environments for a long time and I don't know what the hell of a system the Germans from BIismobil use, apparently there are no fans in sight
there are boat units that replace water with refrigerant, maybe this is the option?
Regards
Fernando.
I was tempted by the Cruise N Comfort VES. But I ended putting in a 3rd reversible vent/fan in the ceiling, 2 very quiet small fans each on front/rear walls, and KCT truly bug proof screens with mosquito and noseeum mesh screens for my 5 openable windows.
Ferjablito
The calculations are supposed to be more than enough for the German engineers, taking into account that they have a minimum of 400Ah/600Ah victron batteries and high-performance panels.... let's say that the electrical item will be around 10,000 euros.
Overlandtec
Isn't your rig 24v?
