Total Composites Slide In Camper Kits
Kofi Levermann
I know it adds some "vehicle specific" work, but what are the chances that if someone was ordering a slide-in kit that they could have the design altered to bump out the rear corners to full bed-width (aft of the wheel wells). I realize it adds several more panels and joints (inside corners, especially), but on the smaller beds, having at least a small portion of the floor-pack that's full-width can make a big difference in fitting everything into a layout. (Good spot for storing a porta-potti out of the aisle, for example.)
Obviously this should include an upcharge due to the extra complexity, but if I were ordering a camper, it's one I'd willingly pay.
The fact that bed space is wasted as Herbie said, is the reason why am not considering TotalComposites. I mean I could really use that space... at least a bit of it. You could also make it a storrage box with extra lil door, to access from outside, for those that wanna store firewood.
The gab kinda destroys the look, it should be filled. I like everything else though
simple
Maybe total composites could offer an add on box kit made with offcuts. It would be a 4 sided box bonded to the outside of the existing design with a hatch door cut through from the inside for access.
Alloy
While I’m not aware of any specific failures, I as a builder definitely don’t want one of these types of failures to happen with one of our campers, therefore I’ll take these precautions into consideration based on the client’s needs. a live testing and not just computer simulations to find the failure point would be costly. The difference between these composite shells and typical conventionally build shells is that these aren’t reliant upon internal framework for structure and instead relies upon the shell and extrusions for structure. What is achieved by this is a light weight shell without thermal transfer through the walls/corner joints. This does have a slight compromise in the distance we are comfortable (for now) offering full N/S cabover sleeping areas.
Not a hard issue to overcome by adding CF inside the panel or bonding alum. to (inside the box) the panel.
rruff
Since CF and aluminum both have a much higher elastic modulus vs FG, they'd be a poor choice for reinforcement. FG would be good but I doubt TC would approve of that.
Victorian
If you look close. There is not much room for widening the rear. You also need access to reach the tie downs.
Blocking the taillights is a no go for us…. That means installing replacements in the camper with added costs.340F2FDF-3F36-4313-8F70-B73B5A75AB95.jpeg
Alloy
Reinforcing fiberglass boats with aluminum is done allot.
Alloy
Might be a good time to bring up CHMSL (center high-mounted stop lamp).
rruff
Depends on the application and how you do it. If the bond is good and the aluminum is strong enough to carry the whole load on its own, then you should be fine.
Adding CF to the panel is the same deal... the CF needs to be strong enough on its own. This is because it is ~3x the stiffness of FG (maybe 5x+ the stiffness of FRP skins). CF will fail long before the FRP skin. For instance a good way to ruin a structural FG laminate is to put a thin layer of CF on top for cosmetics and to add a little stiffness. The CF will fail long before the FG, and the integrity is gone. Best to just use FG.
Alloy
Use enough CF to support 105% of the load so neither the CF or FRP fails. The added material will be in tension at the top and compreesson at the bottom. Both alum and CF are (as you said 3-5X better) for compression.
rruff
3-5x higher stiffness... not strength. FG is much closer in stiffness to the existing structure, so it's better to use that if you want to reinforce it (ie improve the strength) in a specific area.
Hope you let customers know. I got stopped crossing the border for not having one.
Damn... so I need to mount a center brake light on my camper? :oops:
xander69
