@dbhost any pics of the install ?
All the pics are up in the Memorial F150 Craptor thread under Domestic Full Size sub forum...
The monitor is not installed yet, and after testing, and the alternator upgrades, I am upgrading to a 40 amp charge controller / DC to DC charger, so my harnesses will be VERY different. 4ga wire, Anderson connectors etc...
So after considering my needs, options etc... yes I have settled, for now anyway on the following setup.
Atem Power 40 amp Solar charge controller / DC to DC charger. Amazon reviewers say it doesn't work, testing on my own says the Amazon reviews are full of fertilizer.
4ga from truck battery to a 50amp 12v marine stand alone breaker, then to the controller through a set of Anderson connectors.
Truck outfitted with 220amp alternator. Lifetime warranty and it was cheaper than the 160.
For now, single Chins 200 amp hour Lifepo4 battery.
Dokio 300w solar suitcase panel.
Planned future expansion. Second Suitcase panel, SAE to MC4 adapters, cables and Y fitting to get power into the camper via an MC4 weatherproof fitting. Second Chins battery for 400 amp hour total capacity.
This is nowhere near enough power for AC, but will provide more than enough power for the fridge, laptop, CPAP, lighting, furnace and USB charging.  And I do not expect heavy furnace usage.
As far as the Coulumb Meter wiring is concerned. So neg post on battery, through Columb meter as shown, to just any old ground it looks like. That is fine. Positive from battery to Columb meter, and sample wire from battery to meter sample wire connection.  Shielded wire connects from meter gizmo to display, and life is happy allegedly. Do I have this right?
I opted for the 50 amp meter as recommended as I am using a 40 amp charger. any reason to do differently?
