Camper transfer?
jasonwantsout
I EAGERLY awaited my All Terrain Campers arrival, but after spending a couple weeks in it I do not think it is for me, and will be looking to sell. But wonder how people go about the transfer if the buyer is not already set up to receive it. And I do not have the jack stands. Will any RV dealers who mount slide ins do it? Or is it hard to find a shop willing if it isn't one of their sales? I also have the auxiliary battery hooked into truck battery/alternator.
AbleGuy
Officious Intermeddler
Here’s ⬇ how I have loaded/unloaded my camper shells. The below is provided for educational purposes only, solely as an example of what I’ve done.
This is a very dicey operation and great care must be used throughout the entire process. If one doesn’t make sure of having the camper shell in perfect balance on the jacks, or if it’s a windy day, or if one isn’t extremely careful moving the trucks out from under and back under the raised shell, the shell could get easily knocked down injuring the shell, the trucks or the folks trying to do this work. When I’ve done this, caution at all points of the process is my key focus.
1. I Rented portable camper jack lifts (like these⬇) from an equipment rental place and bought an 8’ 2x 6
2. I determined the COG balance point for the pop up shell
3. I put the jacks on both sides of the truck, parallel to those COG points
4. I unfastened the shell from the truck, lifted both sides and slid the 2x6 under it, at those COG points
5. I next put the ends of the 2x6 on the lips of the ⬆ jacks, with help of another, and start slowly cranking the shell up off of the truck bed (don’t do it on a windy day), pause once I have the shell about 2-3” off of the truck bed and double check the balance of the shell, if not in perfect balance, adjust as needed
6. I next raise shell up just far enough to safely drive truck slowly out from underneath it, being very careful not to snag jack stand feet with truck or tires
7. Next I carefully back up the donee truck under the raised shell. Again being careful not to hit the jack stand legs or shell, and making care the shell is high enough for the new truck to get properly under it. I adjust the line up of the shell to the bed sides once truck is fully under the shell.
8. With one guy at each jack, I slowly and evenly lower shell to truck bed, slowly slide out 2x6’s so the shell sits on the new truck bed, fasten shell onto the new truck bed.
jasonwantsout
That is helpful, thank you.
When they delivered I backed under it with no problem, but took it very slow and I'm sure they have guided people back many, many times.
billiebob
Number One.
Calm weather and a flat solid surface. Think WalMart parking lot.
Number Two.
The rule of backing up..... Position, Position, Position, you want to be lined up PERFECTLY before reversing and you want to pull straight out when off loading. Get the wheels straight before lifting the camper. On a SOLID FLAT surface.
DanoWall
