m-l_johnny
And please use small words so I can understand.
As I understand it;
Straight up EV is battery powered with some regen from braking, etc. When the battery bank is drained, you’re done.
Hybrid typically has both battery banks and an ICE. Some regen from braking, etc, when the batteries get depleted to a certain level, or some other criteria is met, the ICE kicks in and propels the vehicle. Some hybrids, like the Chevy Volt, uses the ICE to run a generator, which only sends power to run the electric motor, thus becoming like a locomotive.
So why does no one make a hybrid that uses an ICE to recharge the batteries? Some speculation I’ve heard is that there would be too much heat generated recharging and discharging simultaneously.
Please correct me if any of my preconceptions are incorrect. My mind works in the mechanical realm. To me, electricity is black magic and works on smoke. Let the smoke out it doesn’t work anymore.
As I understand it;
