TripLeader
A few days ago when it was snowing I had the JK out for some errands. As expected, some snow built up on the headlight lenses - the LEDs don't' generate enough heat to keep the snow off. Over the next few months as it snows more I'll be testing some of the "home remedies" found on the internet - things like spraying the lenses with WD-40, Rain-X, non-stick cooking spray, etc. I may also experiment with headlight washers.
I picked up some windshield washer nozzles that could be mounted on the grille below the lights and aimed at the lenses. I checked the adjustment of this one and it adjusts enough so that it could put two streams on the lens.
I've got a bunch of extra JL-style grilles left over from that project and I don't mind drilling them to install nozzles to test this idea. I think the nozzle could go below and to the outside of the lights and they wouldn't be too obvious:
The question is what to spray through them. I could put an extra pump in the windshield washer bottle and spray with washer fluid, but it might be more effective to spray with de-icer fluid. But the JK engine compartment is so cramped it will be hard to find a place to install a bottle. I've got all winter to experiment though. I'll post any results I come up with as it snows and I can test more.
Does anyone here have the LED option on a JL? Does the owners manual make any mention of snow accumulation on the lights?
This is a great project. I'm excited to see the results, or the results with the warmed version.
What are your thoughts on washer fluid vs. some sort of heating ring to melt snow away, or even a optional secondary conventional bulb for heat? Would that even be an option? Or too risky? Too cumbersome?
I'm not an engineer and I'm not handy, so maybe my thoughts aren't realistic.
