givemethewillys
Jonathan Chouinard
I have one, you definitely need some sort of solid mount for it. I poured a 3'x3'x 4" concrete pad, and it still moves when you get cranking on it.
That doesn't sound too encouraging.I have one, you definitely need some sort of solid mount for it. I poured a 3'x3'x 4" concrete pad, and it still moves when you get cranking on it.
For breaking the bead, you probably don't need something so robust, since the force is downward. A pallet may do in that case. The HF tire changer may need reinforcement in the bead breaker arms - mine hasn't bent yet, but I've seen many others that have. I did, however, bend my lever using the bead breaker.That doesn't sound too encouraging.I have beadlocks so the hardest part is just breaking the inner bead. The rest is pretty easy.
I've been happy with it for the most part, but it definitely doesn't replace a commercial unit. Most of my use has been for lawnmower tires, and dried up rollers for my Willys Jeep. I've changed up to 33's with it.Besides needing a solid mount, are you happy with it? I've been interested in buying a similar set up.
Thanks for your advice! I will see what happens as soon as I thaw out.For breaking the bead, you probably don't need something so robust, since the force is downward. A pallet may do in that case. The HF tire changer may need reinforcement in the bead breaker arms - mine hasn't bent yet, but I've seen many others that have. I did, however, bend my lever using the bead breaker.
That is a good description. But he is enjoying every bit of it.I was reminded about Overland Expo West today. Submitted my credential request. Got invited to go wheeling before the show too. I hope this psycho won't be using me as a slalom cone again this year. Who's going?
It's Jack Black!I was reminded about Overland Expo West today. Submitted my credential request. Got invited to go wheeling before the show too. I hope this psycho won't be using me as a slalom cone again this year. Who's going?
