2009 Provan Tiger CX - F-350 $85000
Mister-Richard
SOLD.
Selling our 2009 Provan Tiger CX, Ford F-350 4wd with 82000 miles. Tiger RV Serial Number 1171. We bought it from the original owner five years ago and have used it primarily for vacation trips. It has the original 6.8 liter V-10 with a Ford truck 6 speed manual transmission with a low ratio, compound first gear and factory installed transmission cooler. Original drive train which is the Ford F-350 with one ton single rear wheel axle with heavy duty transmission and transfer case. The clutch was replaced about 3000 miles ago by BLUMENTHAL’s Transmissions in OKC. It has a heavy duty South Bend Kevlar clutch. 335 watt solar system with triple Victron lithium Bluetooth enabled chargers. 200 amp hours of 12 volt lithium batteries and is off grid capable. 2800 watt Onan generator. 600 watt pure sine wave inverter under seat. Fox shock absorbers, Hellwig sway bars front and rear, rear air bags, WIFI Ranger on board cellular wifi system (antenna fin on top that’s holds a SIM card and internal router). Rated to tow 9000 pounds. Goodyear KO2 all terrain tires. Upgraded electric chest refrigerator runs on solar system or 110 volts. 2020 model Coleman quiet series air conditioner. Interior cushions were built by Truman’s Upholstery in OKC. 40 gallon fresh water tank, 15 gallon gray water and 15 gallon black water tanks (all heated). The uncomfortable Tiger jackknife sofa was replaced with a custom built solid maple frame couch system with more under seat storage. Upper bed is a memory foam single with a Froli bed spring system . The two original granite color tables are included (same color as the sink) but not installed (small round and large rectangular tables with mounting post). The Tiger spent its first years in Phoenix AZ, then OKC. Currently winterized and under cover in Missoula MT. Additional pictures available upon request.
Very well maintained and in good condition with all the original books and extensive service records. Selling for $80,000, or best offer over $80,000. Serious buyers only that are familiar with Tiger Adventure Vehicles and their value. Also listed on Craigslist. Thanks.
BajaSurfRig
Out of curiosity what are these red bags in the front coils?
rruff
Just a general question about these rigs...
The frame on older F350s is very flexible C channel. Are the campers mounted directly (like on a box truck)? And if so are there any modifications to the truck chassis to make them stronger?
iStan814
